08-21-2005, 09:01 AM | #1 |
Weird problem.........
I can not get hubcaps on my truck. I've tried 2 sets and neither will fit. I've got 71/72 hubs (I think) from napa, could they be wrong?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
08-21-2005, 05:13 PM | #2 |
its all about the +6 inches
Youy have any pics?
Are these car hubcaps? They won't fit on truck wheels, they'll be too small. |
08-21-2005, 07:14 PM | #3 |
Oops, I said hubcaps, i ment dust caps, that cover the castle nut and bearings on the spindle. I can't get them hammered on for anything. One cheap set from napa and then ordered one set from ECE. I'm runnin straight ralley's with no trim rings or anything.
08-21-2005, 07:40 PM | #4 |
ahhh, that does make more sence.
Is there a chance you have later hubs? How far off is it in size? I'll assume the caps ar just a hair too big... you might get away with putting the caps in the freezer for a while...I wouldn't heat up the hub though. (seen that recomended here before) |
