Old 08-25-2005, 02:30 PM   #1
Johns70
Johns70's Avatar
blazer tops
what is the difference of the two tops single and double wall?
mine i'm not sure what i have, it has two dome lamps, has bolts and nuts that hold it to the bed rails, and on the front it has two clamps and bolts that attach it to the windshield frame.it seems to be a double becuase there is two skins being a out side skin and the a inside is formed similar to the pickup inside.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 08-25-2005, 02:53 PM   #2
easy_13
single wall = bolts to bed on TOP of bedrail
double wall = bolts to bed on BOTTOM of bedrail
normally, single walls have the dome lights; but I guess someone could have installed them in a double wall along the way.
easy_13 is offline   Reply With Quote
Old 08-25-2005, 05:33 PM   #3
orangepunkn
blazer top
I also have a factory top with 2 dome lights and the bolts go down through the bed rail
orangepunkn is offline   Reply With Quote
Old 08-25-2005, 05:34 PM   #4
orangepunkn
woops forgot to mention it is double skinned and and untouched top
Old 08-25-2005, 05:35 PM   #5
Johns70
Johns70's Avatar
what do you me bolts to under or over, is one or the other have threaded inserts for the bolts to thread into? mine just has regular nuts and bolts holding it down.
Old 08-25-2005, 05:43 PM   #6
72BLAZERDUDE
72BLAZERDUDE's Avatar
Its got to be a single wall because there is no access to the inserts on a double wall top and the bolts mount from the bottom.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-25-2005, 05:45 PM   #7
Johns70
Johns70's Avatar
ok thanks for the help.
Old 08-25-2005, 06:48 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
