09-25-2005, 01:59 PM | #1 |
front lower control arm on 69
do i have to cut the steering stop/bump stop down to give me more room or not. i took the springs out and im about 8 inches off the ground well im going to run 3inch drop spindles and do a 3 1/2 z but where i do get the 1 1/2 from if i cut the steering stop i think i can get it, i need help thanks
Brandon 67 chevy CST 68 chevy stepside US ARMY truck 69 chevy longbed green and white Custom10 05 Honda Rancher AT with 26 inch ITP 589's 2008 Chevy crewcab vortec max 4X4 pickup 1969 Chevrolet layin frame Project Fools Gold http://67-72chevytrucks.com/vboard/s...d.php?t=257593 |
09-25-2005, 05:25 PM | #2 |
With a spindle drop, & or Z the frame you wont need to cut the bump stops off the lower arms. If you plan to use a shorter spring, or my guess (bag it & lay the body), yes you will gain some clearance by cutting the bump stops off L
http://community.webshots.com/user/hotrodhorn |
09-25-2005, 06:09 PM | #3 |
well im putting bags on it and i need 1 1/2 more clearence so what im saying is, is it ok to take the bump stop/steering stop off?
09-25-2005, 06:42 PM | #4 |
IMHO, you should have some sort of steering stop. I would torch the complete works of the lower arm, then you can fab the steer stop......you will no doubt need to trim a portion of the outer bottom lip of the crossmember for clearance to lay it tho. my 69 has a 3" shorter spring(cut coil), minus the bump stop, but still has the steer stop, with a stiffener plate on the backside. I use a traction bar "snubber" for the bumpstop, but the steer stop will bottom on the outside corner of the crossmember across the bad potholes in Illinios. Best of luck...... L
09-25-2005, 07:12 PM | #5 |
Hollister Road Co.
You should relocate the stops. If you are bagging and using drop spindles you may have to fabricate some stops. I used part of the original and fabed part of it.
