11-18-2005, 01:09 AM | #1 |
collector of vintage rust
Dipstick with problems
Recently i swapped the motor out of my 71. The p.o. had installed a later model(like '84) 305 out of a monte carlo.Manifolds and all. When i dropped in my old 350 (like 73) the drivers manifold sits right against the dipstick hole...I plan to run some headers eventually, but right now i cant bear to cut the newly run exhaust he had installed since its a daily driver....so my question is....whats my options?..fill up the hole w/ silicon..lol...
11-18-2005, 01:23 AM | #2 |
Project92 SWB stepside
Re: Dipstick with problems
Get a short stick. Change oil and fill to capacity. Put shorter stick in and pull and put a mark on it. DONE
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
11-18-2005, 11:37 AM | #3 |
I did try the shorter tube from the 305. But since it was from pass. side, it still wouldnt work. i had to remove the whole tube from the block to get clearance....Has anyone else had trouble using late model manifolds on an older (lefthand dipstick) engine?
11-18-2005, 12:53 PM | #4 |
lokar has a dipstick that goes right in the hole with no tube
11-18-2005, 04:21 PM | #5 |
thanks,.....that just might work!
11-18-2005, 04:36 PM | #6 |
Ya just dont plan on checking the oil for about 6 hours after you stop I have one and it is hot. I Keep one of those mechanics gloves in my glove box just so I can check my oil.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
