![]() Join Date: Sep 2005
headlight help
okay got an headlight problem i had no high beams so i replaced the floor switch which was sticking no high beams so i been driving for an month with just low beams till the other day when the driver side low beam burned out. so no biggie went to advance auto and got an set if sylvania halogen 60/40 watt bulbs part number h6024 okay i installed them yesterday and boom i got low beam and high beams. drove around for about 5 hours light night no problems. well tonight i start my truck after it had been sitting for about 4 hours turn the lights on and get ready to pull out of the parking lot and the driver side head light flashes (high beams) and goes out next the passager side all in an matter of seconds. okay no biggie i'l just use low beams click the lows on and bam the driver side low beam burns out so i drive home with just the passager side low beam. i'm checked the wireing it all seems fine it seems like the lights flitter when the are on? an i looking at an bad head light switch or volt regaoutor? thanks in advance
Re: headlight help
If your lights are extra bright, it is may be your voltage reg. If it was a short your lights would go out and then come back on as there is a circuit breaker built into the light switch. Here is a way to check to see if it is your light switch:
1--unhook the dimmer 2--remove BLUE wire 3--install a wire in place of the blue long enough to reach the fuse panel 4--attach to fuse panel on a fused circuit that is hot only when ing switch is on 5--drive it this way as lights will be on all the time (you can still use your dimmer to check both low and high beams 6--If nothing blows it should be in your light switch 7--If it blows a fuse trouble is from dimmer out to your lights or your voltage reg. 7--NOTICE- above infomation carries no warrenty.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
71 rustless in texas
Re: headlight help
I had this same problem, it was the voltage regulator. I replaced the headlights and about 4 times and the voltage regulator 5 times in a year. I installed an internally regulated voltage regulator and headlight relays and no more headlight problems.
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" ![]() 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
Re: headlight help
what i ahve noticed is at times the lights are really bright and at others the are dim but what getts me is that when i had my bat. tested at work work and it said surface charge decected please turn head lights on and before you can turn them on it says head lights on detected then please turn head lights off and they are off which means i got an drain somewhere but when i checked everything is off in the cap not pulling power? will an bad volt reg cause an bat drain also?
![]() Join Date: Aug 2004
Re: headlight help
A bad regulator could cause a draw. I have had bad internallly regulated alts draw before.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Re: headlight help
i'd take apart and cleanup the ground wires B-4 doing anything else
Re: headlight help
went to the parts store and had my alt checked and they said it was putting out 19.5 volts so i installed an new volt reg and now its charging at 14 volts so i should be good now i believe
Re: headlight help
okay frist time i've drove my truck in the dark since i've replace volt reg and head lights when i' sitting still my lights flitger and aren't standy any ideas on what is causeing this?
Re: headlight help
Idling to slow. When they are doing this slowing increase rpm to see when they stop flicking. Check grounds--battery to motor--motor to frame-body to motor.
Re: headlight help
whats what i thought my carb idle is adjusted all the way out and i had to bend the bracket the thet thotlle cable goes to just to keep it running
Re: headlight help
What kind of carb?
Re: headlight help
factory 2 bbl carb
Re: headlight help
If you have a camera take a photo of carb linkage--you got something wrong there.
Re: headlight help
no all i know is it looks like it been jimmie riged some how another i'll try to borrow an friends camrea
