Old 12-04-2005, 09:59 PM   #1
Throttle Mod Question
Anyone ever done a modification to have the 71/72 firewall mounted gas pedal on the inside of the cab, but run a throttle rod on the engine bay side?
My 69 has been modified to have a cable linkage assembly, but I prefer the rods. To me the feel better, but I kind of like the idea of the pivot point on the firewall. Figured I would start here to see what great minds have thrown together before I go into the deep think-tank mode.
Old 12-04-2005, 10:28 PM   #2
Sweet72
Sweet72's Avatar
Re: Throttle Mod Question
I'm sure you know this but here ya go anyway... the cables were incorporated for safety reasons. I've never really noticed a significant difference, cable vs. linkage rods. Sorry Bill, my reply contains no useable information for your "brain storming".
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-04-2005, 10:44 PM   #3
pound41
Go to the tech section there is a great post where a member shows step by step with pics how to do it without having to weld. I am getting ready to replace rusted floor pan and was thinking of making the switch. check it out
pound41 is offline   Reply With Quote
Old 12-04-2005, 10:55 PM   #4
Pound41, yes I saw putter's mods, which if I stay with cable I'll be doing.
Sweet72....interesting. I had never heard that mentioned before. Seemed to me that it would be the other way around for safety. Thanks for the input.
Old 12-04-2005, 11:18 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Palf, it is in fact for safety.
When the old style motor mounts break 9which they were prone to do) then the engine would lean to the passengerside, and where ever the throttle was at the moment the mount snapped, that is where it stayed for a moment. Since they normally break when you take off, the throttle would be stuck down a bit further than you woulda have wanted.
There was a recall for the motor mounts, and the throttle cable upgrade was done a couple years prior.
I agree with you on the better responce of the rod. To make this even better you can use sperical ends (heim joints) on the ends of the rod.
Old 12-04-2005, 11:48 PM   #6
I had forgotten about that. Now it is making me rethink. The 69 already has the later style motor mounts and towers. Now I gots to think some more on this change. Not the input I was expecting, but very useful.
Old 12-05-2005, 12:33 AM   #7
chevymad
When the motor mount breaks it doesnt just stick the throttle, it pulls the pedal to the floor! It's a very disturbing sensation having the gas pedal disappear out from under your foot and the car accelerate on its own.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 12-05-2005, 03:28 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Early Mustangs used a firewall pivot rod linkage setup. I removed it from my '67 rustang when I did the 5.0/5-speed swap. You might try adapting something like that. Just don't let anyone know where you got the parts
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-05-2005, 11:12 AM   #9
A few 72's
A few 72's's Avatar
Bill, A friend of mine cut the rod of the 69-70 style under the dash and welded the end of the 71-72 rod on to it.
Allowed the 71/72 firewall mounted gas pedal on the inside, and the throttle rod on the engine bay side
A few 72's is offline   Reply With Quote
