Old 01-09-2006, 05:20 PM   #1
bruce carll
Question rear suspension control arms
I'm working on a 69 C20 and have a 67 C10 for parts. Will the control arms off the 67 fit the 69? All the measurements are the same. The only difference I see is the C20 arms have a strap welded to the bottom,
bruce carll is offline   Reply With Quote
Old 01-09-2006, 06:22 PM   #2
neonlarry
neonlarry's Avatar
Re: rear suspension control arms
They will fit fine, with the added advantage of the extra bracing.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-09-2006, 07:37 PM   #3
Sweet72
Sweet72's Avatar
Fab a new reinforcement for the C-10 trailing arms from mild steel and weld it on.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
