Old 01-15-2006, 07:13 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
How to paint engine?
What is the best was to prep an engine that is already painted for new paint. The old paint is peeling badly. i have started scraping it off, but should I use a paint remover? I have painted two engines in the past and have had both peel badly, what causes this, poor prep??
Also, I've been looking at peoples engine pics on here and a lot of them look super glossy and REALLY ORANGE!! How many coats of paint should be applied??
Basically, what I'm looking for is a step by step for painting!
Please help!!
910
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 01-15-2006, 07:30 PM   #2
68gmcdually
68gmcdually's Avatar
Re: How to paint engine?
I really don't have the answer off the top of my head. I will ask my dad tomorrow and let you know, he sells engine enamels as a side line/hobby to his restoration business. I believe with mine we just really really cleaned it and degreased it, but I can't remember now.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 01-15-2006, 07:46 PM   #3
gentry69
gentry69's Avatar
i have always just degreased them real good get all the oil and residue off and bought that engine paint from parts store but on this motor im gettin ready to drop in my 51 i used a engine primer and then painted it i think it turned out better than usuall
gentry69 is offline   Reply With Quote
Old 01-15-2006, 07:51 PM   #4
68 short step
heres how i do mine.
step 1- remove all pelling paint. any means nec.(scrapper, die grinder with sanding disc, scotch brite, whatever...)
2----- oven cleaner!! soak it down and let it sit for 30-40 min and keep applying it to keep it foaming.
3------rinse with a water hose or pressure washer. repeat step 2 untail clean. may need to get the tooth brush out and hit the lil nooks and crannys.
4------VERY IMPORTANT let dry and put in sun/heated room and it it around 70-77 degree ideal
5------paint it heavy 2 or mabey 3 coats.
6------once dry....and paint has hardened( usually bout 1 1/2 to 2 days) in 70 degree weather.clear it if ya want a shinny finish.
hope that helps
cleaning
paint
68 short step is offline   Reply With Quote
Old 01-15-2006, 07:58 PM   #5
68 short step
and heres a pic of a engine that has been 'cleared'... note that in really hot areas the clear will fade ( i.e. the very bottom of exhaust manifold) havent figured out how to prevent that yet with a cleared engine.
anyone know??????
Old 01-15-2006, 07:58 PM   #6
68 short step
Old 01-15-2006, 08:12 PM   #7
wibilly
wibilly's Avatar
any body here use auto body b/c paint on their engines?
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 01-15-2006, 08:24 PM   #8
Orange70chevy
Orange70chevy's Avatar
I have! Don't know how well it will hold up yet, But it looks good now!
Orange70chevy is offline   Reply With Quote
Old 01-15-2006, 08:27 PM   #9
greasemonkey
greasemonkey's Avatar
Me too, just painted mine.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 01-15-2006, 08:40 PM   #10
matthufham
wait, wash the motor with water? moisture is really bad in a motor, and rushing water is worse. with nothing covering the exhaust valves, spark plug holes, or intake, i wouldn't use water. it'll dry out but won't it damage it?
matthufham is offline   Reply With Quote
Old 01-15-2006, 08:44 PM   #11
gentry69
gentry69's Avatar
i use brake clean several cans or starting fluid thats good to
Old 01-15-2006, 08:45 PM   #12
Joey-D
City's Articulation Ramp
Joey-D's Avatar
I found that hi-temp enamel also works great for painting your stove top, mine was some old 70 almond color and a little 1200 degree white engine enamel saved me a couple hundred bucks for the new stove top. Yes I will admit, I am a gearhead. My finance called me a hoosier, but I really wanted to paint it Chevy Orange.
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
Old 01-15-2006, 08:49 PM   #13
matthufham
oh and also we painted the wheels on my sister's 4runner with engine paint about 9 months ago and they havn't shown any peeling yet. she never washes it either. we just pressure washed them, took the balance weights off after marking them, and masked the tires off. this is autozone brand or oReilys. i forgot if it needed primer, might add that step in but i'm not sure.
Old 01-15-2006, 08:57 PM   #14
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Here is mine I painted it with 1200 deg high temp engine primer, paint,& clear its been on for a year now and still looks awsome !
The brakets are b/c c/c.. I used paint stripper to get rid of the old paint it worked like a champ...
John
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is online now   Reply With Quote
Old 01-15-2006, 09:20 PM   #15
68 short step
yes moisture is bad in a motor. take preventative measures to avoid that.. put sparkplgs in tape all ports and take care not to get water in there. ive done this plenty of times and no problems. just be careful and use common sence. youll be fine
Old 01-16-2006, 12:44 AM   #16
muddpile
muddpile's Avatar
Up here, anyone I know just cleans the engine thorougly with varsol until all grease and oil are gone, scrapes off any flaking paint, and the bruses on Tremclad. Brushing it on they say sticks WAY better than spraying it and you don't notice the brush strokes because of the cast. I'm going to give it a try.
muddpile is offline   Reply With Quote
Old 01-16-2006, 03:16 AM   #17
junior219
has anybody painted their engine to match their color of the truck or vehicle?? if so, what sort of prep, primer and paint did they use?? I thought is would look good with matching glossy paint and some chrome under the hood
junior219 is offline   Reply With Quote
Old 01-16-2006, 07:11 AM   #18
mike nutt
69fatmotor
mike nutt's Avatar
these two engines were fresh builds without any paint , they were cleaned good with brake clean and primed with metal etch primer . the first engine was painted with automotive urathaine the second was ppg base/clear automotive paint. the biggest thing to do to keep your paint looking new is to make sure you've got all your leaks sealed up . oil and gas can ruin your paint over time.
mike nutt is offline   Reply With Quote
Old 01-16-2006, 04:00 PM   #19
MrC1
Dork For Days
MrC1's Avatar
I've always used lotsa carb cleaner and made sure it was very dry.
Then just spray away! Carb cleaner leaes no residue and I've never had paint peel or not stick using this method.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 01-16-2006, 04:31 PM   #20
72MARIO
72MARIO's Avatar
The key all of you are missing is WAX and GREASE remover. Any auto paint stores sell it.Got the right idea just not the right product.
I wire wheel used motors to get all the rust and paint off. Epoxy Prime and Base Clear or Polyurthaine for the finish. If you block get's hot enough to burn off auto paints you have bigger problems to worry about.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-16-2006, 06:50 PM   #21
Mudder
Mudder's Avatar
Just finsihed getting mine painted. It's going back in next weekend I hope. It's got a lot of dust on it here and I can't take pictures anymore.
Mudder is offline   Reply With Quote
Old 01-16-2006, 09:49 PM   #22
69GMC910
MOTORHEAD!
69GMC910's Avatar
so do they sell high temp primer and clear coats?? if so, what brands do you guy's prefer??
910
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 01-17-2006, 01:25 AM   #23
WHYBYNU
WHYBYNU's Avatar
They do make high temp primer and clear. I used DUPLI-COLOR (made by DUPONT) 1200 deg. high temp engine primer/paint and clear. I bought it at ADVANCE AUTO... Get it as clean as you can and clean it 6 more times before you start painting and you will be very happy with the results...
JOHN
71 Cheyenne super
ZZ6 - Th350
4/6 drop
Old 01-17-2006, 07:06 AM   #24
mike nutt
69fatmotor
mike nutt's Avatar
VHT also sells high temp paints and primers , can be found at most speed shops , but i prefer auto paints so i can color match the vehicle.
Old 01-17-2006, 10:56 AM   #25
wibilly
wibilly's Avatar
is epoxy primer suitable for high tem such as heads?
