Old 03-05-2006, 07:55 PM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
Big Block guys, Need Help please......
I had a book laying around that gave you everything you needed to know on how to tell the difference between what CI block you might have, but I can't seem to find it. I need to know where/what to look for on my Big Block to verify it is indeed a 454(Truck came OE with a 350, so it is not original)
It isn't running right either. Doesn't seem to have much low end, and it will hesitate some while driving when you get on it and backfire out the exhaust once and awhile without warning. The pervious owner put an Edelbrock on it, and it may need tweaked some, but I have a gut feeling it is ignition timing. I don't have a BBC book, so does anyone have the spec's?
TIA,
TP
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 03-05-2006, 08:50 PM   #2
68350
68350's Avatar
Re: Big Block guys, Need Help please......
points or hei? Almost sounds like bad points or timing, sorry no specs handy.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 03-05-2006, 10:41 PM   #3
Robznob11
Robznob11's Avatar
specs on a 454 are 4inch stroke 4.25 inch bore. if it is a 454 the last 3 #s of your casting are likley 445 since this block was produced from late 70 to 90s there are also a few other castings. that are mark 4 I want to say that the last 3 #s are 289 or 389 there are also 2 more. most 427s used the same block but they have a shorter stroke crank althouth the 454 crank can be installed to make them a 454. mortec has all the casting #s you need to identify chevys. just do a serch for mortec casting numbers and you will find there site. i build stroker bbc so i can let you know more if you need just email me..
Robznob11 is offline   Reply With Quote
Old 03-05-2006, 10:47 PM   #4
Robznob11
Robznob11's Avatar
the block casting # is located on the block on the lip right above where the bell housing bolts on. should bo on the driver side if you take a flash light and look down on the bell housing behind the intake you should be able to spot it easy on the lip of the motor.... happy hunting...
Old 03-06-2006, 07:00 PM   #5
TP from Cntl PA
Thanks Guys...........Looks like they have HEI on it, but I am not sure. Was going to tear into it tonight, but am feeling a bit under the weather so I am going to wait until it warms up enough to get my steam jenny out and blow the crude off of it before I start wrenching. Supposed to be in the 60's here this weekend which will be perfect.
