Old member
Old Question
I bought a 94 Chevy truck A/C blower motor to replace my 71 blower motor. It didn't work. The squirle cage was to thick on the new one. Oh well anybody have any other suggestions on what year may work.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
its all about the +6 inches
Re: Old Question
I used one from a 96 P/30, and like you described, the cage hit the back side of the box. I made a spacer to moce the blower motor out a little, then I ground down a little bit of the cage and it all clears and seals great.
Blows way harder than the old motor did. |
Old member
Re: Old Question
Thanks for the info on the spacer, haden't thought about doing it, but I would like one to just fit the same hole. I'm open for suggestions... anybody!
