Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-25-2006, 08:44 AM   #26
Hart_Rod
Hart_Rod's Avatar
Re: 1969 Burb build-up (Bags, 5.3/4L60E, repaint, interior....)
Originally Posted by Putter
Holy crap...that gauge cluster is AWESOME. Where did you ever find something like that???? (**wink**)
Hey, if you are running 2700 rpm and have 0 oil pressure, you better shut'er down (see gauges)
Rob, glad to see you got all the parts home safe & sound. We had a great time at the cook out and really enjoyed meeting you and your family.
Oh, I just remembered you wanted the door hinges. You still need them? Shoot me a PM with address if you do...it's pretty dry out there for a change!! Maybe after we get this house done I will come over and you can help me do MY bags!
Yeah, the gauges look great! I know some dude up in Jackson, that does pretty "decent" work . Thanks, again we enjoyed meeting everyone too. Come on down and we'll hammer your truck in no time. While I'm doing the bags, you can wire the gauges up . Any progress on the tailgate?
Hart_Rod is offline   Reply With Quote
Old 05-25-2006, 09:10 AM   #27
My compliments on the guage cluster(and everything).All the right stuff in the right place and looking good while doing it.Thumbs up!
Old 05-25-2006, 09:25 AM   #28
Hart_Rod
Hart_Rod's Avatar
KUDOS again to Putter (with an assist to DJRacer!).
Old 05-25-2006, 09:45 AM   #29
shifty
Questionable
shifty's Avatar
Originally Posted by blazerboy72
Thats the same problem I am having and I am using the S&P plates also. Summit has big block headers for $99 and the flanges are $16 I am going to try that route and maybe I can help us all. Sorry to hijack your thread.
I'm really curious to know how it turns out for you.
Very strange about people having problems w/ECE mounts - they worked like butter for me
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-25-2006, 01:22 PM   #30
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
S&P mounts FIXED my problem.
Originally Posted by Hart_Rod
Chris (CaptKaos),
Just read your build post, nice job BTW. I know ECE designed their motor mount kit for the 67-72. Could this be the problem with the exhaust in your truck? I don't know what the differences are in the frames. Also, do you have some pics and descriptions of your fuel system. What tank, fuel pump, type of lines.....????
Thanks for the props. I talked to ECE before ordering them and asked them what all is included in the kit. I looked at them on their webpage and the pieces they are selling along with the mounts appeared to me they were 73-87 pieces. The guy on the phone confirmed this with me and said they should work without the stands on the 73-87. Well they do if you build custom headers, but I am planning on running either 1 or 2 rear mounted turbos on this and wanted to keep the manifolds....
I don't know what they are doing with the position of the mount as I know you 67-72 guys would have to drill new holes to get the 73-87 brackets on there, but if they mount like mine do, it will be way forward from the normal SBC position.
I already knew I would have some grinding to do to miss the EGR port, but with the ECE mounts it was hitting the frame mount that they are selling you. With using the S&P mount I still had to clearance the EGR port, but with the ECE mounts I would have to cut it completely off, or cut a hole in the frame mount. I have been wanting to see Shifty's pics for comparison, just haven't had the time...
As far as the front section of the frame, the 73-87 is the same as the 67-72. Which is why you can put a 73-87 under a 67-72 to upgrade one to newer parts.
Fuel system I am using a 1987-91 EFI Blazer/Jimmy fuel tank, stock sending unit and a AC241 in tank pump. Out of the sending unit is 3 lines: supply, return, Evap. I am tying the same 3 lines from the LS motor into those lines using hardline down the frame and braided line at the front to the motor and at the rear to the tank. At the end of the hardline on the supply line is the standard AC fuel filter.
I won't take up a ton more room than I already have hi-jacking your thread, but on Post #14 there are 2 shots of the front/rear of my fuel lines running down the passenger side of the framerail. When we pull the body back off after aligning the body panels up better I will post more pics to that thread. I may have some more at home also.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-25-2006, 01:40 PM   #31
Captkaos
Captkaos's Avatar
Found out why they worked for you in your post/pics. You used '98 Manifolds. I used '00 manifolds based on other recommendations. I may look for those now... What specifically are they off of.
http://www.ls1tech.com/forums/attach...chmentid=57781
Hart_Rod, Get these and you will be fine... (sent Shifty a PM on what they are off of) I am guessing a '98 F-body...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-25-2006, 02:37 PM   #32
Hart_Rod
Hart_Rod's Avatar
Hart_Rob, Get these and you will be fine...
Are these from a car or truck???? Where can I get them?
Rob
Old 05-25-2006, 02:53 PM   #33
cwilli84
1FINE69
cwilli84's Avatar
There was someone here in Detroit with an identical rig running a sweet old 409 setup with A/C to boot. Same color . I think he was/is a GM service mechanic somewhere based on the stickers on the Burb.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Old 05-25-2006, 03:08 PM   #34
Putter
More Cowbell....
Putter's Avatar
Nope. None...zero...zilch....
BUT...
We have started the house. We have concrete and some garage walls already! (So there went my free time for the next SEVERAL months)
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-25-2006, 06:49 PM   #35
Captkaos
Captkaos's Avatar
Rob
I am guessing a '98 F-body. I sent Shifty a PM hopefully he will drop back in here.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-25-2006, 08:38 PM   #36
shifty
Questionable
shifty's Avatar
Those are off of a 98 Camaro. I got them off ls1tech (before I stopped posting over there) for $40 shipped.
For a picture of all manifolds available for your application, please see this website which covers a 6.0L engine being put in a vehicle. It shows all manifolds that are stock for every year a ways down:
http://www.4wheeloffroad.com/brandpa...ng/index1.html
This link might go dead in the next 4-6 weeks, so ... if you're really interested in the info on there, you better right-click those pictures and "save as" with a descriptive title for your reference!!
Old 05-25-2006, 08:40 PM   #37
shifty
Questionable
shifty's Avatar
Actually, for the sake of future usage, I am posting that portion here. Here is a caption and a picture which explains manifolds:
The set of ’98 Camaro/Firebird manifolds (top) worked best for us (PN 12567706 RH, 12559507 LH). Other possibilities include ’99-’03 Camaro/Firebird (second from top), ’99-’03 C/K Silverado (second from bottom), and ’97-’03 Corvette (bottom). These manifolds have 2 1/2-inch outlets that Cole was able to build a complete exhaust off of.
Old 05-25-2006, 08:43 PM   #38
shifty
Questionable
shifty's Avatar
PS - another note, just because I can. The second one from the top is actually from a 99-00 F-body. Notice there is a hole for EGR provisions in the passenger side manifold. The '01-'02 had this deleted.
For flow, the top flow the worst but fit the best. The second from the top flow better and have heat shields on both sides, which is a plus, and flow better, but the flange on the passenger side contacted my ECE motor mounts. I wanted to try the truck manifolds, but ... couldn't find any easily. Maybe when I get up and running and actually put an exhaust system on the truck, I'll look into other options. I would really like to find some genuine headers to use...
Old 05-25-2006, 08:43 PM   #39
Hart_Rod
Hart_Rod's Avatar
Shifty, you wouldn't happen to have an extra set of the top ones would ya? I'll be up there July 4th, might be able to help you a little on your bags.
Old 05-25-2006, 08:49 PM   #40
Hart_Rod
Hart_Rod's Avatar
If you want, I can bring mine up when I come up there 4th of July weekend.
Rob
Old 05-25-2006, 10:35 PM   #41
shifty
Questionable
shifty's Avatar
lets just say if your truck ones fit on my setup and they're in good shape, we could definitely trade up if you're cool with that. i'm already using a truck oil pan, pickup, dip stick, lol, list goes on and on and on. might as well try the manifolds too.
Old 05-25-2006, 10:38 PM   #42
shifty
Questionable
shifty's Avatar
oh - and i only have a spare of the second from the top - they've been ground on a little to try to make em fit but nothing major. they're in good shape too. i'm reusing the cats for them because i don't have the resources to drill and weld a bung onto the manifolds - on the f-body manifolds, the passenger side manifolds dont have an O² bung on em, both bungs are on the cat.
do the truck manifolds have an O² bung on them anywhere?
Old 05-25-2006, 11:08 PM   #43
68 short step
i have truck manifolds and they dont fit at all!!!!!! ill see if i can get any pics up...
68 short step is offline   Reply With Quote
Old 05-26-2006, 01:00 AM   #44
Hart_Rod
Hart_Rod's Avatar
Why don't you put the O2 bung in the exhaust pipe? That's what I did in my 48. They're just below the collectors. The truck manifolds don't have the 02 sensors in the manifold, they are in the cats and in the exhaust pipe.
Rob
Old 05-26-2006, 01:09 AM   #45
Hart_Rod
Hart_Rod's Avatar
Didn't get as much done as I wanted to today, but I did get all the holes filled in the firewall (>50!!) and made some patch panels. I also stripped the factory wiring harness off my motor. That took about an hour.
Old 05-26-2006, 01:13 AM   #46
Hart_Rod
Hart_Rod's Avatar
I started to stab the motor, but ran out of time. Just kidding, still a lot to do prior to that.
Old 05-26-2006, 09:45 AM   #47
Hart_Rod
Hart_Rod's Avatar
OK, play time is over, taking the family on vacation. I didn't get as much done as I wanted, but I feel like I accomplished quite a bit (prior planning definitely helped). Hopefully, it is at a point now that I can knock out some serious progress in the evenings after work. Thanks for all the encouragement, comments and suggestions. I'll be back on it in a week or so.
Old 05-26-2006, 09:48 AM   #48
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Sweeeeeeeeeet work
Have a good one
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-26-2006, 07:11 PM   #49
MOTHERTRUCKERS
Wow should be nice when done, your parts will be waiting for you after the cruise.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 05-26-2006, 11:17 PM   #50
Hart_Rod
Hart_Rod's Avatar
Thanks Ed, I appreciate the help.
Made it to first stop on trip, the in-laws in Sebring, FL (as in THE 12 Hours of Sebring). On the way down (9 hour drive), I was able to take care of some business. I ordered a 18 circuit Painless harness from Summit. Gave Stan at ECE a call for a tank and tranny crossmember (man, I knew I shoulda bought some of their stock!). Stan is doing a 6.0 install in his Suburban (I think I passed him this week!) I was telling him about all the issues with stock manifolds. He told me that he as been working with Sanderson to develop some new headers for the 5.3/6.0. He said they should be done in about a month. The first ones will be HPC coated. I asked him to ask Sanderson if they can make them in Stainless also. So hopefully the header issue will be put to rest.
Stan also said that they had a great time doing the OverHaulin espisode. He said that there was a lot more work in the truck than was shown in the 40 minutes of air time. The truck was really worse than they thought, ie they had to replace the rockers, braces, cab corners.... He also said that all of the customizing ideas came from the guy's wife (Note to self: Be carful what you tell the little lady you would want to do to your truck if you could!) Stan would tell you all this himself, but he's to busy selling parts . See everyone later.
Rob
