06-03-2006, 05:46 AM | #1 |
Hydro-boost Question
Has anyone done a swap into a 67-72?Can I use the original p/s gear on the truck?Are hose fittings a bolt-up?The hydro-boost is from an`86 diesel(6.2),what can I use for pump brackets on my 350?Do I need to find a 350 equipt 1-ton in the junkyard?Would the 6.2 brackets work,by chance????
06-03-2006, 09:01 AM | #2 |
Re: Hydro-boost Question
Do you have power steering now? If so your power steering pump will work fine.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-03-2006, 09:23 AM | #3 |
DennisLBrooks has a wealth of knowlege on this. Do a search.
Should be a good set-up - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
06-03-2006, 11:02 AM | #4 |
I was in a wrecking yard yesterday and noticed a late a couple 70's/early80's caddys had hydo-boost set up. I have one on my 85K30. IIRC the power steering pumps are different, they have 2 Hi-pressure lines and one low pressure. I'll see if I can post a pic for you tonight.
06-04-2006, 07:39 AM | #5 |
Thanks,I have the complete system on an`86 diesel Suburban.It looks like mounting on the 350 will be the only hurdle.I`d be amazed if I could just swap the bracketry from 6.2 to 350.I`ll prolly have to get that from a 350 equipped 30.
06-04-2006, 02:35 PM | #6 |
Here are the pics, I had to wait for the rain to stop. There are 3 line ports on the PS pump. The PS brackets are plain ol' long-nose power steering type used on 73 & up. The motor is a 350 Eldebrock crate.
06-04-2006, 03:03 PM | #7 |
The low pressure return line from the hydra boost can just be T'd into the low pressure return line from the P\S gear box. No need to get a special pump.
06-04-2006, 03:52 PM | #8 |
