Old 06-06-2006, 12:34 PM   #1
Nima
Blue 67
Another proportioning valve questions
Hey all:
I couldn't find the answer to this question on the threads that I read. I changed the front to disc and i bought one of these new brass proprotioning valve. I read that I can connect the front brake lines seperately to the valve or I can just use of the the outlet and use a T fitting in the line. Is this correct? If yes, what are the advantages of disadvantages of each rout? I don't know if I could verbalize my question right!
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 06-06-2006, 01:52 PM   #2
Americanrider
Re: Another proportioning valve questions
I have noticed that around 76 & up the P-valves used the 2 front lines from the valve, but they where mounted on the front crossmember. I don't know exactly when they changed the line routs, maybe as far back as 73?
71-72's have the single line that T's near the front crossmember and had the single front line from the P-valve which as we know was mounted near the MC.
Americanrider is offline   Reply With Quote
