Old 08-20-2006, 05:15 PM   #1
jaros44sr
jaros44sr's Avatar
Wood Bed in '72 GMC Jimmy
Here's my current mods and updates:
If I can download the rest of my camera I can send more if you want!! Jim
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-20-2006, 05:43 PM   #2
Big Block
Big Block
Big Block's Avatar
Re: Wood Bed in '72 GMC Jimmy
Did you remove the steel floor? I can see the wheeltubs are mounted on top of the wood floor. Did you use some kind of sealant between the wood and the wheeltubs?
Big Block is offline   Reply With Quote
Old 08-20-2006, 05:53 PM   #3
jaros44sr
jaros44sr's Avatar
Yeah I took out the steel in 5" sections, what a PITA! I redesigned a lot to get it to fit so I could mount the wheelhouses on top. The last crossmember is out of a '73 and up because it has a ledge on it that just happens to be the same thickness of the wood, I wanted steel at the end of the bed for wear purposes. The first crossmember,after the step, is out of a truck, we had to notch it to put a body mount in it! Jim
Yes, I used dum-dum under all the wood where the steel meets it
SAFETY FIRST
AS usual, off topic
Jim
Old 08-20-2006, 06:47 PM   #4
msgross
msgross's Avatar
THey make kits that go over steel floors as well, and they are removeable. saw it on TRUCKS....
msgross is offline   Reply With Quote
Old 08-20-2006, 07:52 PM   #5
jaros44sr
jaros44sr's Avatar
I'm afraid my steel floor wasn't in that good of shape, ended up replacing all crossmembers, I'm working on the last one now. It's the thick one that holds your seat belts and goes between the wheelhouses. Jim
SAFETY FIRST
AS usual, off topic
Jim
Old 08-21-2006, 01:36 AM   #6
smbrouss70
smbrouss70's Avatar
Looks good. I like it. Are you going to be using a back seat?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 08-21-2006, 05:59 AM   #7
jaros44sr
jaros44sr's Avatar
Yes, but not my orig. My nephew has a two person seat that almost matches my fronts. It looks like a Corbeau. Jim
More Pics:
SAFETY FIRST
AS usual, off topic
Jim
Old 08-21-2006, 07:18 AM   #8
jc
jc's Avatar
thats a nice mod (and i dont usually like anything but original) and a
great way to deal with the rust issues.
it must not be to easy other wise i would have seen it done more.
Nice
2004 Silverado 2500HD Crewcab 4x4
2000 TOYOTA 4RUNNER
1971 CHEYENNE LWB (THE LOVE SHACK)
1967 c-10 lwb (THE FARMERS DAUGHTER)
jc is offline   Reply With Quote
Old 08-21-2006, 09:55 AM   #9
Great idea and well done.It makes alot of sense,on thepracticle side.Looks fantastic,on the....looks fantastic side.
Old 08-21-2006, 11:46 AM   #10
ClassicJimmy
FNG to resto/mod world!
ClassicJimmy's Avatar
Would really like to see more pics of the rear floor _ looks awesome! Also, what did you use to coat the front floor area? Is that Lizard skin or bedliner or ?
71 GMC Jimmy - under construction
75 GMC K25 Sierra Grande - under deconstruction
92 Chevy K2500 ECSB - sold
04 Nissan Titan ECSB Off Road - sold & missed
13 Ford F-150 Ecoboost (work truck) - sold
16 Ford F-150 Ecoboost (work truck)
ClassicJimmy is offline   Reply With Quote
Old 08-21-2006, 05:27 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Cool concept, may have to consider that in the Roadster project
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-21-2006, 06:04 PM   #12
Big Block
Big Block
Big Block's Avatar
I forgot to metion, it looks great. Could we see more pictures of the wood floor? Please!
Old 08-21-2006, 06:11 PM   #13
jaros44sr
jaros44sr's Avatar
Nice
Actually it wasn't as hard as i thought, then again it was in the planning stage for 7 months. It just came down to not being able to get a rust free floor, and if it does rot out all I have to do is make my own wood this time as there is not much to them! The '73 and up rear crossmember made it alot easier, the holes that were predrilled were exactly where I needed them for the SS stripes, go figure!
As for the wheel houses, I thought I would have to section them, but I didn't. On the inner fender it has a crease that I had to bend around. I made a slice at the proper height and rebent the flange on the wheel house, and slotted the mounting screw holes,
The hard part was in the front corners, I had to route them out, about a 1/2 day on each one. It does look original, as I to am a fanatic about originality.
Sorry but I can't bring it to Slatington this weekend, I just couldn't get it done in time! Thanks for the compliments Jim
SAFETY FIRST
AS usual, off topic
Jim
Old 08-21-2006, 06:19 PM   #14
jaros44sr
jaros44sr's Avatar
It was Herculiner, real old can, I couln't get all the particles in suspension, so I did 2 coats. Once you put the lid back on the can that's it, it solidifies in the can, no reusing it! Pretty tough stuff, I'll let you know how it holds up. I thought you guys would be tired of seeing pics. It might take awhile, as I just got the camera last night and I'm not to good at it, some of the pics are large. Thanks for the comps. Jim
SAFETY FIRST
AS usual, off topic
Jim
Old 08-21-2006, 06:21 PM   #15
jaros44sr
jaros44sr's Avatar
Thanks.... really like your truck, is that Med. Olive Green? Jim
SAFETY FIRST
AS usual, off topic
Jim
Old 08-21-2006, 06:25 PM   #16
jaros44sr
jaros44sr's Avatar
Would look good all exposed, brings your eye to the interior. My mistake was cutting the boards separately, if I did it again I would measure and cut them all to same lenght, you can't see it, but I know its there. Oh well, everyone has 20/20 hindsight! Jim
SAFETY FIRST
AS usual, off topic
Jim
Old 08-21-2006, 07:26 PM   #17
jaros44sr
jaros44sr's Avatar
You'll have to wait on the pics. as I can't figure out how to download to the server. Worked yesterday. I have 14 pics. of the bed alone! Jim
OK Here ya go:
SAFETY FIRST
AS usual, off topic
Jim
Old 08-26-2006, 01:30 PM   #18
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
That is really nice! I thought about doing the same thing, but my steel floor is so nice, I decided not to. How about doing a FAQ on it so Krue can post it? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-26-2006, 02:57 PM   #19
Rydn2L0w
Active Member
Rydn2L0w's Avatar
That floor looks awesome! Im planning to do the same in the back of my 69 Burban. IT has plywood back there now. So it wont be nearly as much work as yours.
Rydn2L0w is offline   Reply With Quote
Old 08-26-2006, 04:39 PM   #20
jaros44sr
jaros44sr's Avatar
What's a FAQ, and how do you start it? Jim
SAFETY FIRST
AS usual, off topic
Jim
Old 08-26-2006, 04:53 PM   #21
krue
Designated A-hole!
krue's Avatar
A FAQ is a "how to" thread telling (w/pics preferred of course ) how you did the floor. Post it on the FAQ Submissions board, then everyone else who wants to do this will profit from your experience.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-26-2006, 06:36 PM   #22
jaros44sr
jaros44sr's Avatar
So is there any help with this "FAQ" or am I on my own. Do you post it up like a thread? Any further questions, who do I address them to. Sounds like work, do people really want this information? Jim
PS Am I allowed to use company names of my suppliers?
SAFETY FIRST
AS usual, off topic
Jim
Old 08-26-2006, 06:44 PM   #23
jaros44sr
jaros44sr's Avatar
[QUOTE=Rydn2L0w;1790777]That floor looks awesome! Im planning to do the same in the back of my 69 Burban. IT has plywood back there now. So it wont be nearly as much work as yours.[/QUOTE
Maybe you could post up some pics, I am not aware of what a sub. floor looks like. Is it just a longer blazer floor with more crossmembers? Any help on what it looks like would be great! Jim
SAFETY FIRST
AS usual, off topic
Jim
Old 08-26-2006, 06:54 PM   #24
krue
Designated A-hole!
krue's Avatar
If you want you can post it up here and answer everyone's questions (and get their help) and when it is done I'll move it for you.
For inspiration here is a list of almost all our FAQ's
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Here is one I did (a long time ago) for an example.
http://67-72chevytrucks.com/vboard/s...32#post1332032
www.daveramsey.com
Old 08-26-2006, 08:21 PM   #25
jaros44sr
jaros44sr's Avatar
Thanks Krue, will you clean up my grammer as well? Jim
SAFETY FIRST
AS usual, off topic
Jim
