Old 09-15-2006, 02:37 PM   #1
be_el
be_el's Avatar
disc brake conversion for 3/4 ton 4x4
Anyone have any information or suggestions for performing a disc brake conversion on a 3/4 ton 4x4. Truck in question is a 1969 with a small block and 4 spd. manual. Not sure about front axle/diff. maufacturer, Dana I suppose? Anyway, any information would be greatly appreciated.
be_el is offline   Reply With Quote
Old 09-15-2006, 04:08 PM   #2
usaf_gunner
Re: disc brake conversion for 3/4 ton 4x4
Heres a pretty good write up in the FAQ section. There is a bunch of good stuff in there that will probably give you a reason to sink more money in your truck. Good luck with it
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
usaf_gunner is offline   Reply With Quote
Old 09-15-2006, 11:42 PM   #3
Americanrider
Do it! Any Dana 44 front from a Chevy/GMC will work up to the mid 80's trucks.
I used one from a 75 in mine. Disc Brake lines and new U-bolts are a must but you will never look back once it's done. I can now do u-turns on a wide street... something not even attempted with the old closed knuckle axle.
Americanrider is offline   Reply With Quote
Old 09-16-2006, 03:24 AM   #4
Mudder
Mudder's Avatar
Something like this? Only drawback is no emergency brake.
Mudder is offline   Reply With Quote
Old 09-16-2006, 08:11 AM   #5
I thought you meant rear discs at first.On the front,with your year,it`s easiest to swap the axle assembly like AmericanRider did.You can buy an assembly pretty reasonable.The later 10-bolt axles will swap as well.
