Adding a 4th door
Has anyone here ever done or seen a 4th door on one of these burbs? I'm
thinking about doing it, but would like to talk to someone who has first. Thanks. Last edited by boostat4500; 12-13-2006 at 05:47 PM. |
![]() Join Date: Apr 2005
Re: Adding a 4th door
Someone, not sure who, posted this a while back.
I've been looking long & hard at the possibilities of making a 4 door burb out of one of these beasts. What I have come up with is this...(I have all of the stuff to do it to mine ) You will need: pass side B pillar along with a set of 3rd door hinges a pair of front doors(p/u is fine, burb would be better as you will need the window frame First, remove the blank door panel & glass, ect... Carefully remove the section of metal behind the door panel as you will need this for your door glass later on. Next you will be cutting the drivers side B pillar out and moving it back to be the drivers side C pillar(with some mods to the top of it of course). You will take the extra pass side B pillar and weld that into the drivers side. Some cutting & modifying will need to be done(striker pocket flipped to other side & hinge pockets move to other side). Once you have this done, you can start on the 4th door. You should remove the skins from both doors and the window frames too. Cut both inner shells in half. You will need the "latch sides" of both doors shortened to the size of the 3rd door. Once welded together, you can weld in the hinge mounts to the front & remove the panel that would be behind the door panel & replace it with the piece you removed from the body in the first step. Once you are done welding it all in and installing any additional bracing(I would plate the welded areas from the inside and also plate the hinge area to be safe) You can re-skin the door using the removed drivers side skin, shortening it in the front, leaving the correct handle location then shave the lock hole out. Now is when if you used Burb front door for donors for the 4th door, you could cut up the window frames to make the new frames and reinstall the glass... As far as a rocker panel goes, I was going to section a drivers side front rocker panel to mirror a 3rd door rocker panel..
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-13-2006 at 09:45 PM. |
BlahBlahBlah
Didnt Rokcrln cover this in his crew cab build up? This is some fun reading.
http://67-72chevytrucks.com/vboard/s...d.php?t=188993 |
Awesome reply! Thanks a bunch for the info and ideas. I hadn't thought about the B and C pillar stuff you mentioned, great idea! It will have to wait till spring, when I can start riding my motorcycle again, but I think I'll definetly
give it a shot. |
![]() Join Date: Feb 2004
Are there any pictures of any out there?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Wish mine had a 4th door,I sure would use it.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
member
I also remember the article. It was supurb metal work! i wish that I could find the post.
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
Junior Member
try {project penicillian}
BlahBlahBlah
Ummm...I posted the link above on my first post. And here it is again...click and go.
http://67-72chevytrucks.com/vboard/s...d.php?t=188993 Last edited by CG; 12-29-2006 at 12:03 AM. |
Junior Member
my bad
