Old 02-13-2007, 01:11 PM   #1
Foosified
Foosified's Avatar
Engine stalls
This problem seems to pop up once the engine is up to operating temp. I have a rebuilt 350 mated to a turbo 350.
Some symptoms I've noticed:
When first accelerating from a complete stop it's like there is a heavy load for the first second... then it breaks free and accelerates fine.
I think this same symptom is what is causing the stalling. It seems the transmission is bogging down the engine big time. A couple of the times it stalled there was nothing… like driving a 10 hp motor and eventually it seemed like the engine flooded itself then stalls b/c it can get the revs up.
I don't think the engine is the problem because the engine I replaced had similar symptoms.
Is it possible something with the transmission is causing this? Transmission never rebuilt and is original to my knowledge.
I have a new edelbrock 600 cfm carb w/ electric choke and it is running rich, but I am breaking the engine in at the same time so I'm not to worried about that. The fact that the engine is running rich doesn't lead me to believe this is an issue beacuse it runs fine 98% of the time. Stalling only occurs from a dead stop when trying to accelerate.
On a side note what is the best jet size and metering rods for a 350 motor? what size does the Edelbrock come standard with?
Thanks in advance.
BG
May all your ups and downs be in the back of a Chevy!:
Foosified is offline   Reply With Quote
Old 02-13-2007, 01:41 PM   #2
2nd_wnd
2nd_wnd's Avatar
Re: Engine stalls
Sounds like it could be a torque convertor problem
2nd_wnd is offline   Reply With Quote
Old 02-13-2007, 01:42 PM   #3
bobthecop
bobthecop's Avatar
Re: Engine stalls
ttt
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 02-13-2007, 02:30 PM   #4
bryanw1968
bryanw1968's Avatar
Re: Engine stalls
yup.
bryanw1968 is offline   Reply With Quote
Old 02-13-2007, 02:30 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Engine stalls
I have seen transmissions come in that had internal drag created when a band was failing to release or some other problem due to contamination and/or wear,broken hard parts.
My first thought though was that a bad throttle pump on the carb will cause a pause in acceleration. I'm not familiar with Edelbrock but check that you get a good squirt of gas down the carb when you open the throttle.Were you using this same carb on the last engine?
Added:>> If it's the tranny,most likely by now you will smell a "burnt" smell from the fluid (overheated friction material in suspension) and a brownish discoloration.-Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 02-13-2007, 02:56 PM   #6
Foosified
Foosified's Avatar
Re: Engine stalls
Other motor had a Q jet. Current one is brand new and squirts fine.
I haven't smelt the fluid or really had a good look at it either ( it's -21 deg. C out right now ). I plan on flushing the trans. It shifts fine when driving properly?
One other thing I forgot to mention, occasionaly when stopped at a light the truck will push forward as though it is trying to go from 2 to 1 gear? I think this tranny needs a good flush, but would it be worth it to also get a new TC?
Old 02-13-2007, 03:23 PM   #7
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Re: Engine stalls
sounds like the convertor
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-13-2007, 06:16 PM   #8
WorkinLonghorn
Re: Engine stalls
Dang,that's ridiculous!
When you get a chance check that fluid when warm.Check to see that it's got enough in it!!! If it does and it seems "burnt" as described above you may be looking at getting another trans. Torque converters often give out a whining noise as they are going out,and we always replaced the TC and the trans together since they share the same fluid,and thus the same contamination. I really do suspect now that you have simply a low fluid condition.DO NOT drive it further until you check the level and condition of that fluid!!!
Old 02-13-2007, 07:27 PM   #9
gator2511
gator2511's Avatar
Re: Engine stalls
At -21 degrees it won't warm up until June! (sorry, had to say it)
gator2511 is offline   Reply With Quote
