Old 02-25-2007, 04:16 PM   #1
trailrunner
'01 Suburban Odometer Problem
the odometer/trip odometer display has stopped working on my '01 'burban. it's stuck in "trip odometer" mode and won't switch back.
any one ever had this happen before?
and since i'm writing ...... what's the trick for reseting the "change oil" light. i remember that it involves the ignition switched on, truck not running and depressing the gas pedal some number of times. what's the details that i missed?
thanks
bill
trailrunner is offline   Reply With Quote
Old 02-25-2007, 10:19 PM   #2
dailydragger03
dailydragger03's Avatar
Re: '01 Suburban Odometer Problem
can't help with the odometer, but to reset the light just turn on the switch pump the gas 3 times and it should flash then crank the truck and you are good to go.
03 ext cab stepside silverado bagged on 20's with some other cool stuff (daily driver)
1970 c10 short step just gettin started on it (project)
dailydragger03 is offline   Reply With Quote
