Old 03-29-2007, 10:56 AM   #1
67cst
i love summertime
67cst's Avatar
how do i bleed the powersteering system?
just like the question states...my p.s fluid is full of air and its noisy as hell, i had everything apart when the motor swap this winter and put it back together and i got air in there somehow but how do i get the fluid out?thanks in advance...
Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 03-29-2007, 11:25 AM   #2
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: how do i bleed the powersteering system?
Once the air has dissipated from the fluid in the reservoir and while the truck isn't running (might be easier if you get the front wheels off of the ground) turn the wheel lock to lock a few times. Then start it and turn it lock to lock and shut it back off. Check for air in the reservoir again. I do it this way until there is no more air in the reservoir. If there is a better or easier way someone will chime in.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 03-29-2007, 11:44 AM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I am with BACKYARD88 on this one. Let the pump set for about 30 minutes and the foam should settle out. Then add fluid, turn the wheels from stop to stop (with engine off) and check the fluid level. Add if necessary. Then start the engine and turn the wheels back and forth again. Shut off the engine, check the fluid to see if it is still foamy. If it is foamy let it settle out again and repeat the process. It may take a little longer to do it this way, but it is a whole lot less messier. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-30-2007, 07:26 PM   #4
67cst
i love summertime
67cst's Avatar
thanks guys, ill go give it a try
