05-14-2007, 11:11 AM | #1 |
Question? removing rear glass
Whats up guys first post so bare with me. I'm removing the rear glass and I was wondering if some one can give me a tip or 2 about taking the chrome trim off. I'm not worried about the rubber seal I'll replace but I'd like to reuse the trim. any help would be great! thanks BTW its on a 72 cab
05-14-2007, 11:33 AM | #2 |
The Older Generation
Re: Question? removing rear glass
I would just take a utility knife with a new blade and cut the rubber on the inside. Stick the blade between the glass and rubber and get a place started. Once you have it started you should be able to pull the rubber out from the glass to make it easier to cut. Just be sure you keep the fingers behind the blade 'cause it's easy to do some serious damage to your hands cutting it.... Oh, and welcome to the board.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-14-2007 at 11:38 AM. Reason: Forgot welcome |
05-14-2007, 11:34 AM | #3 |
It's a catastrophic success.
Use a razor knife to cut the inside lip of the rubber and the window will pop right out after its out you can take the metal trim out of the rubber.
05-14-2007, 11:37 AM | #4 |
Gone Fishing
I agree. And welcome to the board from Fort Worth
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
05-14-2007, 11:55 AM | #5 |
On the fast track to nowhere..
from South Texas.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
05-14-2007, 12:48 PM | #6 |
Thanks guys I had planed on cutting the rubber I just wasn't sure on the trim. but it sounds easy enough thanks agian and glad to be a part of this great site. So when is the next Ft. Worth get together?
