Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-26-2007, 08:41 PM   #151
Frizzle Fry
Frizzle Fry's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
All the outer quarter panel welds are done and ground. Still need to do the top and the inner panels. Here's a couple shots of the quarters in progress:
Tweaking the gap as I went along:
A million little tacks...
Frizzle Fry is offline   Reply With Quote
Old 05-26-2007, 08:55 PM   #152
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Awesome work, when are you starting on mine?
Owner/Op: "TN Classic Transport Carriers"
Daily Driver: "HerNameIsRio" 68 GMC SWB
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Toy Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-26-2007, 08:58 PM   #153
Frizzle Fry
The notch panel in the 3rd door was originally tacked in place when the body was jacked up off the rear frame. So after getting the body all bolted in place the body lines no longer matched up as well as before. That's exactly why it was only tacked
Unfortunately I needed to move the panel forward to get the arch to line up while keeping the horizontal line matched up. Doing this put the wheel arch forward of the 3rd door rocker
Since this panel had some rust right in front of the lower wheel opening (where they usually all rust) I cut that section out as well as a relief cut to allow the wheel arch to line up with the back of the rocker. Hopefully the pics will make all that clear as mud...
Panel with rust (under paint bubbles):
Panel in new position with rust removed and relief cut (already opened a bit and tacked):
Patch:
Old 05-26-2007, 09:18 PM   #154
Frizzle Fry
Next I tackled the area behind the door notch. Did take many pics of that process but here are some before and after:
Old 05-26-2007, 09:20 PM   #155
Frizzle Fry
...and as you can see in the background of those last pics, I'm now working on the floor covers under the 2nd row seat area.
Old 05-26-2007, 09:37 PM   #156
Hart_Rod
Hart_Rod's Avatar
Looks awesome Mike. Hopefully the other "parts" will be there by the first of the week.
R
Hart_Rod is offline   Reply With Quote
Old 05-26-2007, 11:39 PM   #157
71'tahoe
71'tahoe's Avatar
Hey frizzlefry,
I wish i would have gotten mine finished before the snow storm hit a few years back..you have done what i wanted to do to my 71'.Life in general has kept me from getting a new one to start over with.Your tahoe is so sweet.Glad some one got one to this piont.My plan was to try and make the rear doors more like a 96' style tahoe with more of the arch cut into the door but after seeing the way you did yours,i like it much better.it is a little more proportioned.I really dig it.good luck with it.keep us posted.You should look into doing documentation as a side gig .Good luck with it.Im sure you now know you are the envy of the whole board.Later..71'tahoe
71'tahoe is offline   Reply With Quote
Old 05-27-2007, 01:56 PM   #158
Frizzle Fry
Thanks guys.
Ya HR those parts will be here just in time
71'tahoe,
Too bad about yours. How far along was it? Did you have any pics? Sounds like you were making it even shorter than mine. It would be interesting to see regardless of condition. You should do one again someday. You already have the screen-name
Old 05-27-2007, 11:55 PM   #159
el-cid
el-cid's Avatar
New guy here, I just have to say that this is one of the coolest things I have seen in a loooong time. I read through the '61 buildup so far and that's cool but almost too radical for me. Like somebody said before, this is going to be one of those things that, once done, you'll have people telling you they had or remember seeing before it'll be so well done. Seriously impressive stuff Frizzle.
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
Dr Seuss
el-cid is offline   Reply With Quote
Old 05-31-2007, 01:00 AM   #160
Frizzle Fry
Thanks el-cid. I agree it is a different style. People keep telling me I need to shave it but I say "That's what the 61 is for!"
Back to some progress...
Some goodies arrived via greyhound from Hart_Rod enterprises. Thanks again Rob! Check out how nicely he packed the liftgate (it was all inside a box of coarse):
Take a guess what the truck bed-ends are for...
Here's a final "before" shot of the back end:
Old 05-31-2007, 01:07 AM   #161
Frizzle Fry
Now, before I go into what I'm going to do next, let me preface by showing how trashed my liftgate and tailgate were.
Liftgate:
Tailgate:
Old 05-31-2007, 01:15 AM   #162
Frizzle Fry
So, now that I have a solid set (already had a nice tailgate waiting to go on), I can use the junk set to engineer the one-piece liftgate I've been wanting to do.
What are the circles all about?
I have a big can full of these massive steel washers so... It was a quick and easy way to make them one piece Lower hinges disconnected and folded down under tailgate before welding top to bottom:
Four washers on each side and...
Old 05-31-2007, 01:19 AM   #163
Frizzle Fry
I'm running out of time to write anything so I'll just post the pics I have uploaded and come back to write up the details tomorrow...
Old 05-31-2007, 01:20 AM   #164
Frizzle Fry
Old 05-31-2007, 10:08 AM   #165
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
I think you have done a Terrific Job on your Build, By far it is one of the Best Build's Going. Also Thank You for taking the Time to Document all for us to Follow along with.
Thank You For a Super Build...................
Rick
toomanytoyz is offline   Reply With Quote
Old 05-31-2007, 11:13 AM   #166
Musclerodz
Very cool lift gate. Will that strut stud hold up to the weight of the gate over time? I know my 4th Camaro has fairly large bolts that support the hatch at both ends.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 05-31-2007, 11:21 AM   #167
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Friz that is just awesome. This is almost like a class on fabricating................ Bamm!
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 05-31-2007, 11:32 AM   #168
Frizzle Fry
Thanks Rick/Bamm.
Mike,
It's the same size ball stud and struts used on new Tahoes/Burbs (just with standard threads instead of metric). To my surprise these struts seem to be just a tad on the heavy/strong side for my liftgate. Since I used the same geometry as the new Tahoes (distance from hinge fulcrum to upper ball stud), I guess my gate is slightly lighter than the new ones. Hard to believe, I know. But on the truck I borrowed the struts from that gate is pretty darn heavy with no struts. So if anything the studs are being put under less stress than GM puts them through
Old 05-31-2007, 01:45 PM   #169
Musclerodz
Originally Posted by Frizzle Fry View Post
Thanks Rick/Bamm.
Mike,
Cool, I figured you probably had already thought it through fully as you have with the rest of the modifications.
Mike
Mike Redpath
Old 05-31-2007, 02:37 PM   #170
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Wow, I want you to be my neighbor, feel like moving ot TN?
Old 06-01-2007, 12:39 AM   #171
Frizzle Fry
Originally Posted by LUV2XCLR8 View Post
Wow, I want you to be my neighbor, feel like moving to TN?
My neighbors definitely don't appreciate this stuff as much as we all do.
Old 06-01-2007, 02:15 AM   #172
Britain Smith
Man, those struts from my Yukon look perfect in there.
-Britain
Britain Smith is offline   Reply With Quote
Old 06-02-2007, 12:47 PM   #173
decade22ten
decade22ten's Avatar
howdy. that's a great looking project. the liftgate is that a new piece or a original. keep up the great work.
decade22ten is offline   Reply With Quote
Old 06-02-2007, 05:12 PM   #174
Frizzle Fry
The primered liftgate is a solid used one (they don't make new ones yet). The lift/tailgates that are welded together are my rusty originals.
Old 06-03-2007, 01:03 PM   #175
XXL
Seņor Member
XXL's Avatar
Thanks for the gratuitous crotch shot
XXL is offline   Reply With Quote
