Old 06-01-2007, 07:56 AM   #51
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: My 84 C/10 Progress Thread
From the picture I'd say you want a 6/8 drop.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-01-2007, 01:28 PM   #52
SulphurDave
SulphurDave's Avatar
Yea that picture is a little too low. I like the rake though. I was thinking more like 4/6 or 4.5/6.5? I don't know exactly how low the rear sits yet since the bed is off and I just have some Nissan 300ZX stockers to roll on for now until I get my wheels/tires I'm gonna run. Plus I had a custom built tranny crossmember made to raise the tranny up where it needed to be and give me clearance above it for the longtube headers. I'll eventually get an exhaust put on. But anyway that crossmember sticks down a couple inches below the bottom of the frame rail so I can't go too low.
SulphurDave is offline   Reply With Quote
Old 06-02-2007, 06:26 PM   #53
SulphurDave
Finished bending tubing and making up the gas line today so I figured I'd start her up and see what she does. Fired up first crank.
Old 06-23-2007, 04:35 PM   #54
SulphurDave
Finally got my dash shaved, glassed and painted. Here's a pic. Not that anyone's been commenting in here the past month or so.
Old 06-23-2007, 05:55 PM   #55
DROPPED15
HALF ASSER
DROPPED15's Avatar
Looking Good!!!!!!!!!!!!
DROPPED15 is offline   Reply With Quote
Old 06-23-2007, 07:12 PM   #56
bell
how did you do your dash? IT LOOKS GREAT!!!!
bell is offline   Reply With Quote
Old 06-23-2007, 09:57 PM   #57
SulphurDave
Lots of time, patience, resin, filler, sanding, priming, patience, sanding, filler, sanding.......
Old 06-23-2007, 10:18 PM   #58
bell
It looks amazing! did you strip off the foam and use fiberglass mat??
Old 06-23-2007, 11:13 PM   #59
SulphurDave
nope
Old 06-24-2007, 01:56 AM   #60
oldwagon
oldwagon's Avatar
Paint job is outasite & I like the wheels!!!!!!!!!!
oldwagon is offline   Reply With Quote
Old 06-25-2007, 10:48 AM   #61
SulphurDave
That last picture is just a photoshop of the wheels on the truck but they'll be on there for real sooner than later.
Old 06-25-2007, 10:03 PM   #62
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Wow, that's a great looking dash! That's getting saved to my hard drive.
-- Will
killthewabbit is offline   Reply With Quote
Old 06-25-2007, 10:20 PM   #63
Yankeelights
Yankeelights's Avatar
That dash is Off-The-Hook!
~ Dave
Yankeelights is offline   Reply With Quote
Old 07-05-2007, 11:48 PM   #64
benoit454
Chris
benoit454's Avatar
I love that dash too but I bet it's gonna glare in the window bdly while you try and drive in the sun.
So if you didn't strip it then what was done? Just glassed over the original sanded and painted?
Also what drop exactly are you running now?
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-06-2007, 12:43 AM   #65
SulphurDave
I heard people talk about the glare too but this is not a daily driver and gawt damn it looks good!
Like I said about the dash...
It takes a lot of time and patience to get it smooth. It didn't always come out great looking after the first time it was primed, or the second or the third... I mean we played with it and filled in spots and sanded until it was ready to paint. Don't expect to get it perfect in a day.
All I did in the rear was swap a Ford 9" on top of the leaf springs, took out the overload springs, put on some traction bars and welded up some new shock mounts. This setup came directly out of my 72 Nova. It has a Strange spool w/ 4.11 gears. In essence... it's a "flip kit". I'm fixing to lower the front 4" and slap my new wheels/tires on (12" wide wheels on the rear)
Old 07-06-2007, 06:28 AM   #66
loader820
who did the dash
loader820 is offline   Reply With Quote
Old 07-06-2007, 11:58 AM   #67
benoit454
Chris
benoit454's Avatar
I know how it is to do bondo work.
I've done body work for a few years now so I've been through it plenty.
I just wondered if you used resin and mat, which should stick very well and hold it's own, or if you used a filler/putty like bodno or duraglass.
If you used a filler I wondered if you just roughed up the surface or used some kind of adhesive promoter to help it stick to the dash.
It looks great, love it. I figure no matter if it's a daily or not it's gonna glare and probably bad, my black one does I dyed in my monte carlo and so did the 86 k10's I used gloss black and they glare, but I wouldn't change it to save my a$$. I love anything and everything shiney, just the white might be too much, not sure.
Also what's bad about the fillers is how they don't stay stuck to things that are common to expand and contract or flex. Being white, that helps reflecxt heat so that might help you alot, and if she doesn't set in direct sun for a long time that'll really keep it nice for a very long time. Just make sure some idiot doesn't jam their hand down on it hard and crack it.
Chris
GIT R DONE!!!!!!
Old 07-06-2007, 12:22 PM   #68
SulphurDave
Although it may look white'ish in the pic it's actually tan that matches the paint job on the truck. And yes we used fiberglass resin and mat to make sure it stuck. After that the guy who painted it took it and did his thing with filler and sanding and getting it smooth as possible. Left it alone for a few months just sitting in the inside of my truck. Scroll back to page 2 and you'll see it primered sitting on the dash. Meanwhile, I did some other projects and then came back to it later. Had a couple spots that lifted a little and he went back and sanded it more and filled in where it was neccessary and painted it.
Old 07-06-2007, 12:25 PM   #69
SulphurDave
Here's a pic of the bed where I cut out the fenders to fit some meat back there. I'm having the factory fenders widened to keep somewhat of a factory look.
Old 07-06-2007, 01:32 PM   #70
benoit454
Chris
benoit454's Avatar
I love how people use the factory fenders, but have them widen to clear fat meats. That just lookes awesome when it's finished.
I'm a bit color blind so forgive me for calling it white. I knew it looked darker then white, sorta cream colored or something.
Still yet though it could be turd brown and still look great. I like it.
I'd consider doing it on the next cracked dash i run across.
Chris
GIT R DONE!!!!!!
Old 07-10-2007, 05:45 PM   #71
SulphurDave
Lookie what I got from FedEx today...
Vacuum canister, overflow tank & my exhaust cut-outs. I should have everything installed by this weekend. Maybe I'll actually be able to stop this time when I go piss off the neighbors driving it around the block
Old 07-18-2007, 08:22 PM   #72
mercman1951
mercman1951's Avatar
Since you seem feedback hungry throughout this post: I like the overall approach and the quality of work you've done or had done so far to the truck. I always liked the shortboxes. It sounds mean as well. Nice detailing on the engine compartment.
It's your truck, build it the way YOU want it. Screw other's opinions...follow what your tag line says.
On other boards I'm on, people asking for feedback often wind up hearing stuff they didn't want to hear, and then start getting all defensive as to why they did what they did, which to me, defeats the whole purpose of asking for it. That takes away from a build, IMHO...and since you're doing such a great job thus far, and it seems as though you are stoked about the progress, why have anyone shoot down what you've already done?
The truck looks great. It's not necessarily my style, but having been a body man in a former life, I can appreciate the quality job you have there.
I also admire the fact that you're building this truck as a tribute to your Dad, and doing what YOU want to see done the WAY you want it done- i.e. the dash.
How's that for feedback??
mercman1951 is offline   Reply With Quote
Old 08-04-2007, 06:37 PM   #73
gringoloco
A guy with a truck
gringoloco's Avatar
Truck is lookin' good! I left you some suggestions on wheels in the Coy's thread. Good luck, and keep the pics comin'... -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-04-2007, 09:57 PM   #74
randyjohn
randyjohn's Avatar
love everything about your truck. looks b*tchin.
i was wondering if you thought about boxing your frame where you put the c-notch in? might be a good idea if you plan to take it to the track to minimize frame twist and flex. just a thought.
It's peanut butter jelly time.
'74 GMC 3/4 TON 2WD LB
randyjohn is offline   Reply With Quote
Old 08-05-2007, 09:28 AM   #75
munroe
munroe's Avatar
which ratchet shifter did you use? i was lookin at gettin a hurst truck pro matic 2 or ab and m truck mega shifter. how was the install ?
87 chev wrangler
munroe is offline   Reply With Quote
