Active Member
![]() Join Date: Jul 2007
Howdy, y'all. Here's my project for when I retire. I've had it for about 15 years and used to drive it occasionally. Now that I'm retiring, I'm going to make it a driver again.
I'm getting some good info from this site again. Fantastic bunch! Here's my question. There's a label in the warranty book that has this on it below the vin number. Anyone know what these numbers mean? RXSTD 3.54 1D112657 TRSM318 GMC8 ![]() |
its all about the +6 inches
Re: Warranty label quetion...
is the label a metal tag?
Sounds like the protecto plate. These numbers are a code that show certian things about your truck. The original owner's name and personal info should be on there too. When ever it went in for warranty work, they'd slide that thing like the old school credit card slder things, and it would go into the paper trail of work done to that truck. |
Dave's not here, man
Yep, those things are pretty neat. I still have a work order for my truck when it had a carrier bearing replaced under warranty. You can see where they copied the protect-o-plate info in the corner of the work order.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Active Member
Re: Warranty label question...
Yeah, Longhorn. It's a metal plate on the back of the warranty book my buddy gave me when I bought the truck. Has the name of his father and address etc..
I wonder if the RXSTD 3.54 has anything to do with the rear end ration? Could the TRSM318 have something to do with the transmission? btw: here's a pic of my 69 that I've had for about 20 yrs. That will be next on my list of "to do's." ![]() |
was your truck originally a big block truck? I *think* that's the only way to have gotten that gear...and even then, I don't think it was in 1/2 tons. I think the 1500 trucks got a 3.07 with a big block.
If you do a search on protecto plate... you may find the info. This one cat had a link... he pops in every great once in a while. |
![]() Join Date: Feb 2004
I No See Pictures
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Active Member
Longhorn. Re: big block ?...
The truck is original with 250 six, 3 on the column. I added power steering, power brakes and changed the trans for another with synchronized first gear for convenience. That's the only thing different on it. I will get under the rear end and check for numbers. Re: 72army not seeing pics. Can anyone see them??? Since I'm not familiar with the photo stuff they may not have come out... |
I can see them.
unless optioned otherwise, or swapped out at some point, it'll be a 3.73 gear
