Old 07-19-2007, 12:51 AM   #1
AMD6769
transfer case
Hi to every one I have this 72 blazer and I put a 6.0 charged with a 4l60e and not sure which transfer case put in . It was a allwheel drive and I pulled it off. A friend and I was messing around he had a np208 w/right hand drop and it bolted rite on but it dont have VSS on it like the tc.
AMD6769 is offline   Reply With Quote
Old 07-19-2007, 01:37 AM   #2
Russell
Professional Grade
Russell's Avatar
Re: transfer case
An NP241 fits the bill perfectly!
It is nearly identical to an NP208 in appearance, is identical as far as dimensions go, uses the same shifter and bolts straight up anywhere a 208 will, but is available with a VSS, and has a slightly better low range as well. You can get them with both 27 and 32 spline input shafts, which are interchangable with relatively little work as compared to other t-cases.
You can buy them from Blazers, Jimmies, Suburbans and Crew Cab pickups from 89 - 91. In 89 they have a speedometer cable drive like the old transfer cases, but in 90 it was switched out to a VSS. If you find an 89 case, you can swap on a VSS tailhousing without any modifications. From NP241 has been available in the half ton trucks since 88 but is a driver's side drop, so you have to get it from the old body style trucks with the solid front axles
Despite being a 3 year only case, they arn't really that hard to find, but they are a bit more expensive. I paid 500 for a rebuilt 89 case since I need the speedometer cable drive until I make my 6.0L swap. Used VSS cases would go for closer to 300 or so.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 07-19-2007, 09:29 AM   #3
Yukon Jack
Yukon Jack's Avatar
Re: transfer case
Welcome to the board. Be sure to jump over the the 69-72 Blazer forum and post some pics of your project.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-19-2007, 09:36 AM   #4
1969k10stepside
Re: transfer case
Welcome to the board,and I agree with Yukon Jack,post some pics in the Post Your 4x4 Pic thread and also in the blazer section when you get a chance
1969k10stepside is offline   Reply With Quote
Old 07-19-2007, 11:26 AM   #5
AMD6769
Re: transfer case
thanks for the info and will post some pic today if I can do it. This is a very good forum. thank you guys again
Old 07-19-2007, 02:12 PM   #6
Chris27
Blazerless
Chris27's Avatar
Re: transfer case
You can also get a speedo cable to VSS adapter. There are a few sources for this. Try Bowtie Overdrives or Painless Wiring. That's what I used for my 700R4/350TBI swap. The EFI needs VSS signal, and I was ablt to keep my stock speedo. Cheaper than a t-case swap too.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
