Old 12-23-2002, 01:41 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Question Master cylinder is leaking
My master cylinder has been seeping fluid for over a year. Now it is leaking more. It's leaking right where it's bolted to the booster. Is the master cylinder shot or is there a gasket or seal between it and the booster that needs replacing?. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-23-2002, 01:43 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
The master cylinder is shot.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-23-2002, 01:55 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I figured that. It looks like a new one is $40-$60. Is it pretty easy to change?. Looks like a simple bolt on.
Jim
Old 12-23-2002, 03:17 PM   #4
marcuspboldt
Registered Abuser
marcuspboldt's Avatar
Yes it is easy to change. Be sure to bench bleed the new unit first
(the new one should come with instructions on how to do this, and some plastic tubes and fittings) Then you need to bleed the entire system.
Good luck.
marcuspboldt is offline   Reply With Quote
Old 12-23-2002, 03:52 PM   #5
tom hand
CCRider
tom hand's Avatar
Actually if you follow a few simple steps, bleeding the whole system is not necessary. Bench bleed the master cylinder, then install it. Now just barely move the petal, 1/16 to 1/8 of an inch. It helps if you have the hood open and the top off the master cylinder. You will be able to see all the air you introduced "burp" back up thru the master cylinder. When the bubbles quit coming up,your done. Have done hundreds this way and never had to bleed the whole system when just replacing the master cylinder.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-23-2002, 04:07 PM   #6
sgtjed
What if?
sgtjed's Avatar
wow! 40-60 for a new one? get one at autozone with a lifetime warranty for 19.99. thats what i did. sure its rebuilt but i have not had any bad luck with it.
sgtjed is offline   Reply With Quote
Old 12-23-2002, 05:02 PM   #7
70c10
67-72 Addict!
70c10's Avatar
Thanks guys. Sounds easy enough. I guess if a rebuilt one is o.k. , I'll go with that.
Jim
