Old 09-03-2007, 08:58 PM   #1
gary67
brake pedal will not come up
i am working on a 71 i bought a new master cyl and brake booster
i used a old perportion valve.
the pedal wont come all the way back up with out help should i adjust the rod going to the master cyl
or buy a new valve?
gary67 is offline   Reply With Quote
Old 09-03-2007, 09:42 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: brake pedal will not come up
Check the bellcrank assembly behind the booster. Spray it with WD40 and work it some and see if it helps. You may even have to remove the pin and clean it up, then re install it.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 09-03-2007, 10:31 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
How tight is the nut installed on the bolt that connects the booster linkage to the pedal? It only needs to be tightened enough to allow the cotter pin to be installed.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 09-03-2007, 11:39 PM   #4
wibilly
wibilly's Avatar
did you bench bleed your new master
common sense isn't so common anymore
wibilly is offline   Reply With Quote
