09-10-2007, 09:20 PM | #1 |
well my electrical system is being stupid
since ive bought my truck in june, ive started to notice more and more that the lights flicker all the time while driving. ive had to replace one, and the dash is only lighting up the speedo, and only half of the gas gauge lights up. me and my dad have tried to figure out the problem, we know its not the alternator, we think it might be the regulator, but we don't know. im new, and he hasn't worked on his own cars/trucks in awhile. any idea's?
1972 C10 Custom Deluxe Longbed Fleetside (currently apart in the garage) '69 C10 Custom Deluxe Shortbed Fleetside (all original, including the brown recluses!) 1990 C1500 Shortbed Sportside |
09-10-2007, 09:30 PM | #2 |
I am a Referee of life.
Re: well my electrical system is being stupid
The charging system and wiring is 40 years old.The dash lights may be as simple as a bulb change,there are several under the dash behind the guages.You will think you belong in Circ-De-soliel by the time you get to and find all of them.The flickering you see in your headlights is fairly common,if you look in the FAQ's section you will find upgrades for the alternator,headlight wiring with relays, and many other wiring problems.Member krue has done a good job of trying to build an index of the FAQ section it saves a lot of work searching.
You may have a bad regulator or alternator(if the battery doesn't go down the alt is probably good).Also check your v-belt the sides of the belt should contact the sides of the pulleys to give the proper grip for a V-belt.As for changing a light bulb that is just a maintainence item and could happen to a month old car. BTW the bulbs for the dash lights are small sockets with a flat handle to rotate them and get them out,the bulbs just pull out and new ones push in.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 09-10-2007 at 09:31 PM. |
09-10-2007, 09:37 PM | #3 |
thanks, i figured as much that it probably would be simpler to go to the facts, but i never now. but one thing i forgot, the dash lights flicker in unison with the headlights. i'll go look at what you told me to, thanks
09-10-2007, 09:58 PM | #4 |
sounds like a good time to chagne to a internal reg alternator http://67-72chevytrucks.com/vboard/s...d.php?t=119379
did mine in 30 mins paided 39 buxs for the new alt. got it off an 83 chevy k-10 with 350. best thing i ever done no more flicking head lights or anything
09-11-2007, 12:46 AM | #5 |
Mine would do the same. So im looking under the hood and tracing wires, and nothing.....................until im inside at the floorboard dimmer switch and it turns out its daisy chained thru that darn little switch!!! Moving it with my hand flickered the light as if i was driving. Bad ground was all it was.
09-11-2007, 07:18 AM | #6 |
BAD GROUNDS// it continues to amaze me the time wasted amout of parts part changers go thru when lots and lots of time a piece of 80grit sandpaper cleaning up and old rusty ground connection will solve the problem
09-11-2007, 03:15 PM | #7 |
well then me and my dad will go through it again this weekend and clean up the grounds and see if that helps. thanks guys.
