11-21-2007, 10:50 PM | #1 |
Addicted to Chevy
Degreasing the engine bay
What have you guys used that seems to work the best? I need to clean of the top of the intake, valve covers, block, etc. they have that nice thick layer of grime that seems like its- i dunno 30 some odd years old!!
11-22-2007, 12:09 AM | #2 |
STOLEN
Re: Degreasing the engine bay
You can try Gunk and a preasure washer, but I don't know if it will harm the old paint.
In Search Of |
11-22-2007, 12:42 AM | #3 |
Dave's not here, man
I use some stuff called B-52. I get it at the local parts house. You have to dilute it a bit when spraying on painted surfaces because it will eat through paint at full strength.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
11-22-2007, 01:54 AM | #4 |
SWB 4x4 Collector
I have tried the trick of using gasoline, works wonders. Did it on a transfer case a few years back. Gas will eat threw the grease and grim. Hope this helps, but anymore, it maybe cheaper to buy cans of degreaser.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
11-22-2007, 02:59 AM | #5 |
super clean and a wire brush
Jeff 1967 GMC 3/4ton LWB, Orginal Straight 6, 4 on the floor Project truck |
11-22-2007, 03:43 AM | #6 |
Gunk has always worked good for my projects. I just use a garden hose to wash it off. You do not want to over do it with the water pressure. I've always detailed an engine afterwards so I've never been too concerned about condition of paint or the paint for that matter. Gunk comes in spray or foam I've always used the spray.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
11-22-2007, 05:11 AM | #7 |
chrome makes it go FASTER!
Dollar store oven cleaner and a trip to the car wash. CHeaper than brand name degreasers and works great. Car washes have a grease seperator so that junk doesn't get in my water.Don't spray on motor and then drive to car wash, stinky!
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
11-22-2007, 06:09 AM | #8 |
its all about the +6 inches
steam cleaner
11-22-2007, 11:17 AM | #9 |
Addicted to Chevy
i was thinking about the dollar store degreaser... gas is too expensive.
11-22-2007, 11:25 AM | #10 |
Soak with Simple Green and let it sit for a while then rinse it off. Depending on how baked on the grease is you may need to take a stiff bristled brush to it before you rinse it off. Works better and a lot cheaper than degreaser and no fumes.
11-22-2007, 12:00 PM | #11 |
spic-n-span granules with water and a stiff parts cleaning brush then rince with a hose or powerwasher has always worked pretty good for me
11-22-2007, 12:16 PM | #12 |
What has always worked really well for me, and it's cheap, is dish washing liquid, a scrub brush and "hot water". Hook your water hose to the hot water side for the washing machine. Wear a pair of rubber gloves (hot hose you know) and go at it. Works really well.
11-23-2007, 04:34 PM | #13 |
Another vote for Simple Green. Use it full strength, spray it on and let it sit a few minutes then spray off with hose. You may have to do it a number of times and like already said if the stuff is really thick, use either a wire brush, or if you don't want to scratch the paint, use a stiff bristle brush. I did mine that way and it turned out nice. When it ran on the driveway underneath it also removed the oil spots!
11-23-2007, 05:08 PM | #14 |
yes, i do
i used carb cleaner when i cleaned up the motor that i put back into my 60. cleaned it up really good and ate through all the grease grit and grime. but it took me like 3-4 cans and a bunch of rags to get it clean though.
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
11-23-2007, 11:14 PM | #15 |
Aluminum slot wheels rule...
Super Clean will put Simple Green to shame, at least in my experience.
11-24-2007, 12:03 PM | #16 |
I use deisel smoke remover from our steam store combined with pressure washer on our Rock drills. It cleaners all the baked on grime, oil etc. I just put it in a spray bottle spray it on let it sit for 15 min. then rinse off. Should work on an engine, same basic grime, also cleans my work cloths.
1969 4x4 Nothing beats a good rock drill and some dynamite |
11-24-2007, 03:03 PM | #17 | |
Need a bigger hammer..
1968 GMC 3/4 LWB fleetside Custom Camper 2018 Silverado High Country 2500HD Duramax 4X4 |
11-24-2007, 03:32 PM | #18 |
USMC
Gasoline is kinda FLAMABLE too!!! wow diesel will work and be safer if your going that way. It stinks and will stink for a while after your done and its greasy so if you want to paint on those areas its a pain to prep.
It kinda gets down to how much actual labor you want to put in.
Semper Fi |
