PROJECT 7DEUCE
Project 7deuce
Figured I may as well post the progress of my other project too seeing as how I finally got the pics resized and ready to go. Some of these pics are pretty old but here goes,but 1st a little background on the truck. My dad bought the truck back when I was 8 or nine not sure which anyways we moved from cali to oregon with it and when I got done with h.s. my dad gave it to me for completeing school and then I moved out and have had it ever since... So on with the pics and history lesson..
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
PROJECT 7DEUCE
Re: Project 7deuce
Finally here we go The truck started out with a 350 and muncie 4 speed but I blew that up and then went througha few 305s the last one was 7 years ago and I have not driven it since. First things 1st I had to swap out the frame cause the one under it was bent so I got a3/4 ton truck and stole the frame out from under it got all the 72 sheetmetal bolted up. I dont have pics of any of that as I did not have a digital camera back then so here we go with the rebuild........... Heres a few pics of how it looked before it really got carried away... Started shaveing the bed pockets,door handles,and heater box, and started looking for a new tailgate..
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 11-23-2007 at 11:47 PM. |
PROJECT 7DEUCE
Re: Project 7deuce
Not a new tailgate but one that was in better shape than the one I had. And some pics of the firewall..
PROJECT 7DEUCE
Re: Project 7deuce
Another rear shot still needs better bedside but I got the lwb for free so I cant complain. I had also shaved the cowl vents but the cowl has since dissapeared not sure what happened to it but I have got another one..
PROJECT 7DEUCE
Re: Project 7deuce
Finally had moved into the new house that has a garage and managed to get the new bedside on..
PROJECT 7DEUCE
Re: Project 7deuce
So I cleaned up the 454 and bought some cheapie valvecovers and decided to get it runnin before I took it back out..
PROJECT 7DEUCE
Re: Project 7deuce
Heres a shot of the motor and the shaveing has began.... Also a shot of the made just for you clamps that I used to hold the braided fuel line on the frame.
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 11-24-2007 at 12:22 AM. |
PROJECT 7DEUCE
Re: Project 7deuce
Some shots of the 68 front clip I scored and its finally looking like a truck.
Looks really good, love the front clip. keep up the good work.
PROJECT 7DEUCE
Re: Project 7deuce
Thanks some of the pics are not in the right order but when your looking at pics from 3 to 5 years back its hard to remeber what was when?
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 11-24-2007 at 11:32 AM. |
PROJECT 7DEUCE
Re: Project 7deuce
Heres a few videos from when I had it running shes almost ready to fire agian cant wait..
http://www.youtube.com/watch?v=H5J_rTtYM8c http://www.youtube.com/user/frenchblue71 http://www.youtube.com/watch?v=u3chfA7Ln7c
PROJECT 7DEUCE
Re: Project 7deuce
Looks like I have someone else giddy to get the truck back on the road.. Heres the start of the 1 1/2'' front crossmember chop. Cut it apart and then since im no pro I had to make filler pcs...
PROJECT 7DEUCE
Re: Project 7deuce
One thing to remeber when you do one of these chops lots of welding and grinding and liberal use of the tape measure..
PROJECT 7DEUCE
Re: Project 7deuce
Finally some por 15 was laid on and she was ready to go back into the frame.. One thing you got to remeber was the dropmember was not out when I started this otherwise I would have gone that way..
#15 |
PROJECT 7DEUCE
Re: Project 7deuce
So I figured that since that por 15 looked so good om the crossmember I may as well change the frame from gray to por 15 black... Got the crossmember fitted and when I was happy with the fit off it came agian.. And I figured while I was at it I may as well weld up all the holes in the frame now that I have been going back through these pics I see why these things thke so long.
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 11-24-2007 at 09:29 AM. |
#16 |
PROJECT 7DEUCE
Re: Project 7deuce
A few pics of the front clip shinning in por 15 and then it happened nate joined the board and it was time to order some parts and heres what showed up..
#17 |
Re: Project 7deuce
Great Job!!! Ain't this fun!!!
Alex
Alex 1971 Lil' Red 350 SBC 700R4 |
#18 |
PROJECT 7DEUCE
Re: Project 7deuce
So now its time to install the airride tech strong arms bags and shocks...
#19 |
PROJECT 7DEUCE
Re: Project 7deuce
Ya its fun but I should have done this pic thing along time ago cause it sure is some work...
#20 |
PROJECT 7DEUCE
Re: Project 7deuce
It was at this point that we had found out that they had sent the wrong front shocks and mounts. I had also decided that I needed to order some drop spindals and new rotors along with new lower u-bolts and new uppernuts and alignement shims.
#21 |
PROJECT 7DEUCE
Re: Project 7deuce
I got all the front end stuff done and back together and had a few steering issues to deal with but as xxl says nothing a little grinding cant fix and you can see why I need new lower u-bolts. I powdercoated the a-arm nuts with my new eastwood kit...
#22 |
PROJECT 7DEUCE
Re: Project 7deuce
Heres pics of the completed front end and the start of the firewall shave...
#23 |
PROJECT 7DEUCE
Re: Project 7deuce
I decided everything on the firewall had to go so I broke out the welded and metal working tools and got to work ... Little advise the top gutter fill is a pain in the azz I cannot believe how long it took.
#24 |
PROJECT 7DEUCE
Re: Project 7deuce
Time to break out the mudd for the firewall...
#25 |
PROJECT 7DEUCE
Re: Project 7deuce
Not sure how many hours I had in to the cutting ,welding and sanding of the firewall but it felt like forever.
| Bookmarks |
