12-28-2007, 10:51 AM | #1 |
235 & Hei?
Ok I see many HEI distributors out there for every I6 chevy made, except 235. Is there something That I need to be aware of before buying HEI distributor and trying to drop it? Please offer a little insight..
Thanks..... |
12-28-2007, 11:12 AM | #2 |
Re: 235 & Hei?
Ithink any small block hei v-8 would work on 235.
12-28-2007, 11:13 AM | #3 |
Re: 235 & Hei?
nice burb you have!!!
12-28-2007, 12:09 PM | #4 |
Re: 235 & Hei?
I ran a pertronix in my old 235, and am using it in my 250
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
12-28-2007, 12:29 PM | #5 |
1962 C-10
Re: 235 & Hei?
I believe HEI's are offered for the newer sixes, 194, 230, 250, and 292, but for the older 216's and 235's, you may have to go with slepysal's suggestion...Petronix...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
12-28-2007, 03:05 PM | #6 |
Re: 235 & Hei?
Ok after a few hours of research I've figured it out. The oil pump drive is different, the closest thing to what I need would be 250 st8 6 HEI. Even with this it requires some slight modification. It would seem that it's about 3/16 to short to fully engage the oil pump drive. So the 250 HEI has to have the mount boss removed and a camp installed about 3/16 to 1/4 in further up the shaft. this ensures full oil pump engagement and also full engagement of the camshaft gear.....
Thanks for your help...... |
12-29-2007, 08:47 PM | #7 |
Cantankerous Geezer
Re: 235 & Hei?
Here's what I consider to be the best way to rework a HEI dizzy for the 235. http://www.stovebolt.com/techtips/HEI_mini.html
If you don't mind the huge head that GM used on the 250 go here. http://www.stovebolt.com/techtips/hei_conversion.htm
Fred There is no such thing as too much cam...just not enough engine. |
