Old 01-24-2008, 04:04 AM   #1
mtndewmaniac66
Do the Dew!
mtndewmaniac66's Avatar
Desc brake conversion from a van?
I have a question regarding a disc brake swap from a Chevy 1/2 ton van. I have read, followed links, and even copied posts, but I do not see anywhere on if a cross member, or other suspension/brake components are interchangeable. Of course I will be also using the rear axle in order to keep the lug pattern the same all around. (I can cut/reweld perches and mounts) Can anyone shed some light onto this? Trucks are becoming less popular, (oil field use) and full size vans are becoming more popular. I have a source for a 1978 Chevy Endura 1/2 ton for only $100.00. (no engine or tranny)
mtndewmaniac66 is offline   Reply With Quote
Old 01-24-2008, 06:54 AM   #2
john
member #16
john's Avatar
Re: Desc brake conversion from a van?
I dont know about spindles or other parts, but i've heard there is a width problem with a crossmember swap.
john is offline   Reply With Quote
Old 01-24-2008, 06:57 AM   #3
Blazer1970
Blazer1970's Avatar
I am not sure what the crossmember looks like in a van since they are unibody except for the latest body style.
Blazer1970 is offline   Reply With Quote
