03-01-2008, 12:01 AM | #126 |
Re: Welders!
Northern tool has there welders on sale now. Here is the one I have I haveent used it yet but for the price and it comes gas ready http://www.northerntool.com/webapp/w...2925_200342925
Earl 68 2500 4x4 GMC Burb |
03-12-2008, 10:58 AM | #127 |
Re: Welders!
how is this welder? I found a used one local for cheap. will it do body panels ok?
http://www.daytonamig.com/Pturbo130.htm
Anthony Last edited by 68c10owner; 03-12-2008 at 10:59 AM. |
03-12-2008, 11:06 AM | #128 |
USMC
Re: Welders!
probaly will depends how cheap you found it for. I would go for a miller esab or lincoln at that price though similar models go for about the same or less brand new and have a 3 year warranty on the whole thing not just transformer
. for a couple hundred bucks though it ought to be good to go
Semper Fi |
03-25-2008, 05:14 AM | #129 |
Re: Welders!
Well, finally broke down after looking on flea Bay, bargain trader, local paper, and local pawn shops and bought a new Lincoln 3200HD. Will look over the instructions tomorrow, set her up and start practicing. Been a number of years since I've done any welding so I'll need to shake off the cobwebs. THEN I can start making repairs on my truck. Looking forward to making some progress!
Later, Paul
1972 c10 2000 FLHTC 126+k miles, so far 1967 BMW r60 2007 Xterra (Wife's ride) R.I.P. "ESLL" |
03-25-2008, 06:17 AM | #130 |
Re: Welders!
The last time I ran a bead was about 9-10 years ago with aLincoln weld pak 100. i did ok with it since it was flux core and no expereince. The other day I did a little welding at work with a Snap on welder and gas and I was surprized how decent my weldes were.
Anthony |
04-01-2008, 05:01 AM | #131 |
86 C10
Re: Welders!
what welder would y'all recommend to use on exhaust pipe and mufflers? not something to expensive something that would get the job done and not have any problems. thanks.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
04-01-2008, 05:47 PM | #132 | |
Re: Welders!
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!! |
04-07-2008, 06:11 AM | #133 |
Guest
Posts: n/a
Re: Welders!
Ive got a 135 lincoln mig, a lincoln AC/DC arc with a poor mans Tig, and a cheap ebay 40 amp plasma. All of them serve their purpose and work great. If any one is looking into starting tig welding and you have a AC/DC arc welder pick up a tig torch and a bottle of argon and start welding, i know it doesn't have the variability of a expensive tig and no foot control or welding aluminum but it will put down some really nice strong beads.
04-08-2008, 02:58 AM | #134 | |
USMC
Re: Welders!
TH53 what kind of plasma cutter do you have? I have one loaned to me but I need to have one for cutting sheet metal ?
Semper Fi Last edited by DURRTY; 04-08-2008 at 05:14 AM. |
04-08-2008, 04:38 AM | #135 |
Guest
Posts: n/a
Re: Welders!
DURRTY I have a Everlast 40 amp plasma i works good, better than i expected, it was around $400 to my door. One thing is though if you decide to go with a cheap china plasma be sure to buy a big batch of consumables with it becuse you will be laughed at if you try to get them at a welding supply store.
Ty |
04-15-2008, 04:42 PM | #136 |
Re: Welders!
Does anyone know some one in the long island area that could weld some parts on for me?
04-24-2008, 02:38 AM | #137 |
UCA63
Re: Welders!
Any opinions on a Hobart 140 with gas conversion kit (for doing tin mainly )
as a first welder purchase. 110v ( had 220v but only 2 lightbulbs and 1 plug-in,so i split it a couple of years back for 8 ft florescents and more plug-ins) I am a novice (wait,,,I mean a virgin) at welding. Like anything I've been new at, don't want bottom of the line stuff,but don't think (as a beginner)I need top shelf stuff either. Was also thinking of the one from sears thats mentioned on pg.1 of this thread (but no response)and haven't seen any mention of the 140 ,any feedback would be awesome. would like to get one this week before the other half decides it should be spent on something more important (LOL like there's anyting more important right now).I already got stalled out last year for that. I plan on practicing alot before I even touch my truck. Appreciate it, Thanks, Trent
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
04-24-2008, 10:02 PM | #138 |
USMC
Re: Welders!
That one will work well for "tin" ( body work? right) its the same or real real similar to the miller and Lincoln 135-140 welders we have talked about.
one thing though, if your breakers are stretched out with allot draw on them the welder will blow the breaker or at least not run to consistent. try to get the welder on its own breaker and a 20amp if possible. other wise turn off as much as you can on the circuit you are plugging the welder into. It will still run decent if you cant just a FYI. I am no electrician, I am speaking from experience, and many trips to the breaker box. Once I got my garage wired properly the welder ran much better and didn't blow the breaker(20amp) again. also if you have to use and extension cord use the biggest gauge wire you can. I also have my 220 on its own 50 amp fuse.
Semper Fi |
04-25-2008, 01:15 AM | #139 |
Active Member
Re: Welders!
I bought a Hobart Handler 140 and put gas on it and it works great. I have done all my welding on my truck with it. Works great on sheet metal and welds up to 1/4 which works for me because nothing on my truck is 1/4 anyways. I also did my c-notch and it worked like a charm.
04-25-2008, 01:37 AM | #140 |
Re: Welders!
i have about 800 dolars to spend help me choose a welder
04-25-2008, 02:01 AM | #141 |
Re: Welders!
What is a good Mig welder that Is not to much cash? I want something to learn with and not spend a ton of money on.
04-25-2008, 10:07 AM | #142 |
USMC
Re: Welders!
go back through this thread your question should be answered
Semper Fi |
04-25-2008, 12:04 PM | #143 |
UCA63
Re: Welders!
Thanks DURRTY,the durability of my fuse box has kind of been in the back of my mind since the start.If I have to have it upgraded then I will.
I'm positive now that the HH140 is the one for me. spr85GMC, My budget also is 800.00 I'm pretty sure I can get all my basic stuff for that much,the bottle I'll need might put it a little over that,but i haven't shopped for the cost on one yet Thanks guys. Trent
04-25-2008, 06:17 PM | #144 |
Active Member
Re: Welders!
With my Hobart Handler I was welding for under $800 including the tank,gas, and wire. I bought mine from Northern Tool and came with a cart and free shipping.
04-25-2008, 11:55 PM | #145 |
Re: Welders!
i know right now i wouldnt trust my self on welding in a c notch but would this one work good to do that? its not going to receive daily use maybe once a week if that.
04-27-2008, 10:54 PM | #146 |
Re: Welders!
will this welder work for what i need to do? i need to weld on rockers and quarter panales
Amazon.com: Northern Industrial MIG 125 Wire Feed... |
04-28-2008, 09:26 AM | #147 |
Active Member
Re: Welders!
05-06-2008, 03:41 PM | #148 |
Re: Welders!
I just popped for a Miller Millermatic 140 with Autoset. I considered the 180, but it just seemed like more than I would need and I liked the idea of being able to use the thing on house current even though I have a 220 outlet in my garage.
http://www.millerwelds.com/products/...c_140_autoset/ $649 at the local Central Welding Supply - "blowout" pricing I bought a spool of non-gas wire just to see if I can still weld I'll go back and pick up the cart and bottle next weekend. Last edited by Billla; 05-06-2008 at 03:43 PM. |
05-13-2008, 05:22 AM | #149 |
Insert Witty Text Here
Re: Welders!
Hobart Handler 187 will do anything you need on your truck. You could get a HH 140 if you want to go with a 120 volt machine, but I wouldn't use it for any heavy stuff like frame work.
Slonaker (not an expert on welders, but learning ) |
05-17-2008, 07:50 PM | #150 |
I'm a poor spectator
Re: Welders!
BOUGHT ME A WELDER!!!!!
Picked up a Miller 175 in very good shape from a fellow board member and coworker. Need to get the right outlet in the garage and make me an extension cord so I can drag it out onto the driveway.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
