Old 03-27-2008, 01:16 AM   #1
steverino66
Column Wiring Adapter?
Anyone ever found a steering column wiring/plug adapter to wire an 83 tilt column into a '66 truck?
I checked Ididit and Centech, no luck so far.
I have both trucks' wiring diagrams - would it be easier to just connect one wire at a time? Suggestions appreciated.
steverino66 is offline   Reply With Quote
Old 03-27-2008, 04:00 AM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: Column Wiring Adapter?
You could go pick up the opposing end of the 83 plug, and move everything wire by wire from the 66 plug. Should be pretty easy to do, and if you ever have to remove the column, you just plug it right back in!
PrerunnerRob is offline   Reply With Quote
Old 03-28-2008, 08:34 AM   #3
wild one
Registered.........
wild one's Avatar
I just performed this to my 66' this weekend when I swapped in my "newer" tilt column. It worked out great.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 03-28-2008, 09:23 PM   #4
steverino66
Thanks, guys - I have that other plug end; I'll get out the wire crimpers and heat shrink!
Old 03-29-2008, 12:05 AM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
If you have the right plug you shouldn't need to cut wires as long as the terminals are the same. With a small, thin flat screwdriver you can go down into the plug from the terminal end and release the tab on the terminal. That releases the terminal so you can pull it out and put it in the other plug.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
