Old 05-06-2008, 02:35 AM   #1
Sammy
Power steering hose question
Is the power steering gear box port different for the 68 /69 and the 71/72?
I have a 68 frame with a Pwr gear box and the new braided line is suppose to fit a 72. But seems to be different on the gear box. Looks similar but must be a different animal. Any in sight?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-06-2008, 06:31 AM   #2
lytemup454
lytemup454's Avatar
Re: Power steering hose question
i'll give you a bump
lytemup454 is offline   Reply With Quote
Old 05-06-2008, 04:41 PM   #3
Sammy
Ttt
Old 05-09-2008, 01:52 AM   #4
Sammy
No one?
Old 05-09-2008, 01:56 PM   #5
Luvlegs
Luvlegs's Avatar
I hooked a 70 pump up[ with my 72 box - the new hoses I picked up (72) came with a brass fitting - 1 mpt end and what I remember being a flare end - that screwed into the pump and the hose went on.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 05-09-2008, 03:24 PM   #6
Sammy
Thanks for the reply. my problem isn't on the pump side that connection I'm good. It is on the gear box pressure side. Not sure without pulling inner fender well what the problem is on my line.
Old 05-09-2008, 04:17 PM   #7
Luvlegs
Luvlegs's Avatar
I don't know if these will help or not....
1972 C10 L6 3OTT
Old 05-10-2008, 08:04 AM   #8
pocoloco71
pocoloco71's Avatar
I absoutely can't remember the size, but I called summit racing and there
were 2 sizes, I got both. I think they were like 11/16 and 3/4. Anyways
I can go measure it tommorrow if need be. Any way here is a picture off of
my 1971 with braided hose hook up.
borderline crazy& crossing the border often
pocoloco71 is offline   Reply With Quote
Old 05-10-2008, 03:52 PM   #9
Sammy
I ordered a new presure line from GMC pauls see if this solves it. It appears the inside diameter of the tubing/ or threaded connector is slighty incorrect. I will post follow up if this solves it. Thanks for replys.
