Greetings, can I switch out door guts, or the doors themselves in order to improve to a power window set up for my 75 Blazer? How about upgrading the tailgate to power roll window?
Secondly, what experience has anyone had removing paint from a Blazer top and restoring it to it's original white Patina surface? Thanks, Greg. |
1 of 3 questions -
I got lucky and found a Burban at PickurPart that had electric rear window. Got the switch, wire harness, motor, cable and adjusters for $10. Works great, motor mounts were already there. (1985)
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock http://www.oplnk.net/~spirit/K5front.jpg |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If you are using factory GM guts, they won't bolt up. That is the difference in the 73-76 doors to the 77-91 doors; where the power window motors mount.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Captkaos, regarding the doors, are you suggesting that power windows were an option in 1975, and that they are different after 77? If so, I could chase down a 73-73 Blazer with power windows.... sounds like a remote chance of finding that, but worth a shot!
85K5, I think the tailgate door may be different for 77 and later, but I'll hunt for a 73-75 tailgate with power, I'm just not sure it was offered. Thanks for the responses! |
No, I am saying only trucks made AFTER 1977 had power accessories. No 73-76 trucks had power accessories. You have to find a truck after 1976 to get power. If you want a power back window, you need to look for the same.....
