Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-24-2008, 05:34 AM   #351
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: "Slowly but Surely" Big J's build thread...
Tonights fun... I started drilling the spot welds on the window frame but I'm taking my time on those. Put the trim rings on my wheels, looks sweet! I got the top skin cut off the truck top. Took some pics so yall could see what one looks like inside, RUSTY!!!
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 05-25-2008, 07:09 AM   #352
hugybear
lookin good
hugybear is offline   Reply With Quote
Old 05-28-2008, 04:00 AM   #353
Big J
Big J's Avatar
Got the windshield frame piece cut out tonight. Used a new spot weld cutter instead of using a spotweld bit. Worked great. Still wasn't working fast enough for me so I busted out the grinder and ground out the rest of the spot welds. The new piece fits just like its supposed to. I'm going to fix a few places on the inside first and then por15 all the places I can reach. Here are some pics. You can see all the rusty goodness that fell out in the floor.
BAZINGA!
My Build
Old 05-28-2008, 04:07 AM   #354
jamie72
jamie72's Avatar
so how did he roof tie into the driprail? looks pretty good!!
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-28-2008, 04:19 AM   #355
vtblazer
vtblazer's Avatar
That's great you were able to make use of it, cool yours was still good inside.
'Nother check off the list.
vtblazer is offline   Reply With Quote
Old 05-28-2008, 06:21 AM   #356
OLD SKOOL K5
Good choice on the tires and rims Big J . you can't go wrong with rally's and bfg muds. They are Classic !
OLD SKOOL K5 is offline   Reply With Quote
Old 05-28-2008, 03:28 PM   #357
Big J
Big J's Avatar
They rock don't they!!! How are your trim rings holding up. The way the rubber bead sticks out on these tires seams to be holding the ring out away from the wheel. Maybe I need to take a rubber mallet and beat them on there a little better.
Hey jamie72... I'll take some close up pics one night this week.
BAZINGA!
My Build
Old 05-28-2008, 11:27 PM   #358
jaros44sr
jaros44sr's Avatar
Got anymore pics of the windshield repair, nice wheels and tires. As soon as my govurn' check gets here, I plan to buy the same tires (can ya PM me the price, so I can shop around)
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 05-30-2008, 09:30 PM   #359
Big J
Big J's Avatar
Close up pics.
BAZINGA!
My Build
Old 05-30-2008, 10:58 PM   #360
jaros44sr
jaros44sr's Avatar
Thanks J...do think they used enuff spot welds, I can see why my w/s rusted out. With that front pc. off, would I have access to the rear pc., sorta looks like it. Or is there another layer to get thru?
Where's hugybear???
SAFETY FIRST
AS usual, off topic
Jim
Old 05-31-2008, 03:41 AM   #361
Big J
Big J's Avatar
Nope, take the front pc off and thats it. Yes, definitely plenty of spot welds. I can see why though. The front piece is a much heavier guage steel than the rest. I guess its a big part of the support that ties it all in. Not sure about hugy. I'm sure he's hangin' some place.
I got it all POR15ed and some pin holes welded in. I'll get it mocked up and clean all the spot weld places, then weld it up. I picked up some new rolock discs, Blaze by Norton. I think they are going to last better than 3M, way better than the cheapies. These were only 21.00 for a box of 25.
BAZINGA!
My Build
Old 06-04-2008, 05:24 PM   #362
Big J
Big J's Avatar
No progress.... Moved a deck and a out building around at the house this past weekend and I'm still recooping after that, lol... I was flipping through some pics and came across this blazer. I really like the chrome wheel well trim. Mine may end up with some.... Ran across some other neat pics too...
BAZINGA!
My Build
Old 06-04-2008, 06:04 PM   #363
woodymm3
woodymm3's Avatar
hey man that is a sweet roll bar in that blue one. i like the top too is that silver? great build man still tuned in watchin every move waitin till i have to do mine
woodymm3 is offline   Reply With Quote
Old 06-05-2008, 07:57 AM   #364
Huck
Huck's Avatar
Great progress---one thought though--make sure you are getting that upper piece aligned very nice to the frame. If it isn't, you will wind up with a broken windshield as the strain on it will come and go with the flexing of the body so you want no high points or low points in the frame for the rubber to sit in. You may have to hammer it a bit to get-er-done just right.
Huck is offline   Reply With Quote
Old 06-08-2008, 11:02 PM   #365
Big J
Big J's Avatar
Heres the windshield frame all welded up. It lined up perfect and went in pretty easy. I think I had every small clamp and visegrip I owned on it, lol. Several that saw it laughed and made fun... All thats left to do to it is strip and epoxy prime it. Along with a healthy dose of seam sealer... I also modded a stock fuel fill cover to fit my needs. I Spread it out some, then cut and filled the bottom to cover the filler tube. The next thing I need to do is strip the bed sides and get some epoxy primer on it so I can get to finishing up on the body work. But what fun is that.... I think I'll fiddle with the truck top I cut off first. On to the pics....
BAZINGA!
My Build
Old 06-09-2008, 07:16 AM   #366
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Great progress Big J.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 06-11-2008, 10:16 PM   #367
Big J
Big J's Avatar
I'm trying....
Piddled with the truck roof tonight. I'm thinkin' I don't like it, at all..... It wouldn't be hard to brace it up, weld some tabs to bolt it to the windshield frame and to the rollbar light tabs. I can picture it complete with paint and the blazer lookin' all nice. But it still just doesn't look right to me. Any suggestions?
BAZINGA!
My Build
Old 06-12-2008, 05:22 AM   #368
jaros44sr
jaros44sr's Avatar
It's probably just because it's new and differant to you, you're used to seeing it one way, give it a chance to grow on ya. JMHO, but I think it looks good on there. If my hardtop mod. doesn't work out, I'll probably go your route, but I have to make it longer...Nice progress!
I think that you have the largest collection of clamps on the board, LOL
SAFETY FIRST
AS usual, off topic
Jim
Old 06-12-2008, 06:01 AM   #369
vtblazer
vtblazer's Avatar
Anyway to move the tubing forward and tuck it under the metal roof section?
Do you have any pics of it from above or above/behind angles?
Geese...that almost sounds perv-ed.
Old 06-12-2008, 06:45 AM   #370
Chevyman63
Chevyman63's Avatar
Remember Kurt...this is a family friendly site.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-12-2008, 06:48 AM   #371
Chevyman63
Chevyman63's Avatar
I agree with Jim, give it some time & I'm sure once you get some more sheet metal (doors & fenders) on it, it will take on a whole new look.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-12-2008, 08:57 AM   #372
Big J
Big J's Avatar
I knew they'd come in handy one day, lol.... I was at a local tool store that sells close outs and they had 80 gallon drums full of vise grips. 2 for 8 bucks.... I loaded up and bought some Christmas gifts.
I can't move the roll bar forward but I think I'll cut the back of the roof then bend it up to go over the roll bar. Then weld in pieces to fill the gaps. The roll bar behind it is mostly whats bugging me. Nothing wrong with perv'ed.... Perv'ed it funny
This side is, lol... I reckon you've never been to the darkside
BAZINGA!
My Build
Old 06-12-2008, 03:17 PM   #373
jamie72
jamie72's Avatar
imo.. i would just get a soft top or bikini top, as i`m not liking the look either..lol
jamie72
member #807
www.antlertalk.com
Old 06-12-2008, 05:54 PM   #374
5150
C10 Club Tennessee
5150's Avatar
Me either, but if you could get a pic of your cousin sitting in the cab I'm sure it would help my opinion
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-12-2008, 06:07 PM   #375
jamie72
jamie72's Avatar
that would work..lol
jamie72
member #807
www.antlertalk.com
