Old 08-08-2008, 11:13 PM   #1
Purs
Got Big Block?
Purs's Avatar
Ignition switch
Long story, I've been trying to figure out what the PO has done with the wiring in my '72 Blazer. I finally think I've traced the trouble down to my IGN switch. Both the red and the pink wires are hot all the time. Isn't the pink only supposed to be hot when the key is in the RUN position? As a result, my IGN spades on the fuse panel are hot all the time. Why is this important you ask? Because I need a wire to tap into to run my HEI. Right now, I have it hooked to the IGN spade (which is hot all the time) so I have to use a toggle switch to turn my truck off... Anyway, I've put my test light on all the different spades on the back of the IGN switch and none of them are hot when the key is in the RUN position. The purple wire goes hot (like it should) when the key is in the START position. So does it sound like my IGN switch is bad or should I be checking something else? thanks in advance for the help.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 08-09-2008, 02:18 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Ignition switch
Sounds similar to mine. The PO had pulled the wires from the plastic plug and "rewired" it so there would be a hot lead all the time. Then they put in a toogle switch to kill all the power.
Replaced the switch with a new one from NAPA, wired it as it should be and all is working great now.
Do it right and replace the switch. My .02 worth.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-09-2008, 10:09 AM   #3
Willys47
Willys47's Avatar
Re: Ignition switch
when I wired my HEI I pulled the resistive wire that went to the old coil out of the back side of the fuse holder. Then I installed a new wire and ran it to the HEI, it is key on power and worked with out a glitch.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 08-09-2008, 03:27 PM   #4
dakman
Re: Ignition switch
I used that pink wire to run my hei on my 72', it should only be hot with the key in the on position. It goes from the ignition to the fuse block and back to the engine bay. I'll look under the dash and check to see that someone hasn't moved the wires within the plug on ya because if I remember correctly there should also be a green.
dakman is offline   Reply With Quote
Old 08-09-2008, 03:35 PM   #5
dakman
Re: Ignition switch
nope.. everything looks proper on yours. Mine has a green but it's just for the temp gauge dummy light test when the key is first turned on. Might be the ignition switch shorted internally or trace the wires back and see if someone has spliced them to another hot somewhere.
Old 08-09-2008, 04:06 PM   #6
Wrenchbender Ret
Re: Ignition switch
The use of the term. is usually written on the back of the switch. The red is hot & the pink goes to the ign. The purple goes to the S term on the starter or to a neutral switch.You can buy a pigtail connector with about 2-3 in. of wire .
Wrenchbender Ret is offline   Reply With Quote
