09-14-2008, 11:45 PM | #1 |
Blinker Stem/Arm
The stinkin' blinker stem broke off. What exactly is the part that it mounts into? Does anybody know? I hate to start buying a bunch steering wheel components that I don't need.
I appreciate the help. Greg |
09-15-2008, 12:20 AM | #2 |
Inline 69
Re: Blinker Stem/Arm
it mounts to your turn signal assembly "in the column",
which means you'll need to pull the steering wheel After you get to that point you'll know if that assembly is cracked... or needs replaced. jeff |
09-23-2008, 09:33 AM | #3 |
Live fast, die young
Is the steering wheel the only thing you have to pull to get to the assembly? I need to replace mine. And I'd like to put the steering wheel back on straight too...
Mine's a '73, but I figure close enough. Last edited by D-Day; 09-23-2008 at 09:34 AM. |
09-23-2008, 11:41 AM | #4 |
Always on the hunt...
09-23-2008, 01:34 PM | #5 |
Sierra Grande Club
Make sure the part you by has the provision or a straight arm. Some of the ones they were selling as a replacement had it at an angle. Also the Assemblies had a different Hazard knob.
I got my stuff from Wes @ Classic Heartbeat. (he has the correct stuff) s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
