02-24-2003, 12:10 AM | #1 |
Mickey Thompson Radial MTX tires??
I was thinking about putting some Mickey Thompson Radial MTX's on my truck as soon as the current tires wear out. Anyone have good/bad luck with these tires, or hear anything about them? I plan to use them for mostly street, but some mild offroading will be in the plans for them too.
Also, what is the biggest tire size I can run stock (w/o lift)? Thanks.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
02-24-2003, 04:15 PM | #2 |
I am a DIE-HARD BFG guy. Michelins for street tires, BFG for offroad. (BFG is owned by Michelin) I'd get you some new BFG all terrains for mostly street driving, mud terrains if you are going to be off road a lot.
33 12.5 should fit fine with no lift on a 10" wheel. I ran 33 14.5 on an 8" wheel with only slight rubbing on the leaf spring during sharp turns. For your 2500, you will most likely need 16 or 16.5 rims, especially if you want to do disc brakes and have'nt. If that is the case, I prefer 16's over 16.5's and maybe even 17's except tires are pricey. I would do 305 75 16 which is ~ 33 12.5 16.
