Old 11-28-2008, 12:45 PM   #1
superpieboy
superpieboy's Avatar
stock three spd transmision rebuild
Hi everyone
i am looking for information about rebuilding my stock transmission in my 62 chevy, i was told it a saginaw, two months ago i took it out and took it to a transmission guy locally and he looked inside the transmission from the side cover and we determined that the gears were great , and we would just reseal the tranny and focus on the linkage, trying to pin point why my tranny will not stay in second gear, i bought new bushing for linkage ect ect and still i have to hold it up in second gear and easy on the engine torque as to not force it out, i dont want to drive it like this, i did adjust my linkage and it is a close to perfect as it can be, without any lock ups between shifting ect. i can find anyone locally who would want to tear it down and totally rebuild it so i will do it myself, i just need a book on it and a kit , can anyone help.
thanks alot
jeff
superpieboy is offline   Reply With Quote
Old 11-29-2008, 08:15 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: stock three spd transmision rebuild
I have a 3-speed out of my '63.....that I'm not using anymore....shifted perfect.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-29-2008, 05:56 PM   #3
Woogeroo
are these the same 3 speeds ?
http://www.kinzers.com/don/landcruis...ons/index.html
parts, rebuild kits, plus a illustrated exploded view drawing:
http://www.drivetrain.com/saginaw3_4sp.html
I hope this helps, if it doesn't apply, sorry.
-W
Woogeroo is offline   Reply With Quote
Old 11-30-2008, 08:31 PM   #4
factorystock
factorystock's Avatar
There was two 3 speed transmissions, a light duty GM 3 speed and a heavy duty 3 speed built by Warner. It is common for the linkages to wear out and cause trouble.Used linkages will be just as worn.It would be a good time to replace the unsynronized(1st gear) 3 speed with a sm420 4 speed, only modification would be a longer driveshaft and hole in floor board.
factorystock is offline   Reply With Quote
Old 12-08-2008, 12:06 AM   #5
superpieboy
let me just ask this question, when we use the term three on the tree are we saying its a three speed ( three forward gears) plus reverse. or is this tranny a four speed and reverse counts as fourth?
thanks
jeff
Old 12-08-2008, 12:48 AM   #6
PrerunnerRob
PrerunnerRob's Avatar
Only the forward gears count, so a 3 on the tree is a 3 speed.
PrerunnerRob is offline   Reply With Quote
Old 12-08-2008, 12:59 PM   #7
LILRED66
LILRED66's Avatar
ditto with a 4-speed...four forward gears, plus reverse = 4-speed.
LILRED66 is offline   Reply With Quote
Old 12-08-2008, 03:07 PM   #8
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
I have the original 3 speed transmission out of my 62. It has been rebuilt, painted, and still on the engine stand. Have the 3 speed columb shifter as well.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 12-09-2008, 03:17 PM   #9
MikeN
MikeN's Avatar
-W
This data is related to the 66 and later Saginaw 3-speed, which is all-synchro and much larger than the 65 and earlier Saginaw 3-speed, which is non-synchro on first and very small.
MikeN is offline   Reply With Quote
