Some "Z-ing" Questions unique to my application?
whats the minimum Z for a 70 chev Shortwide to get it to lay frame? I am assuming I will have to modify the trans tunnel and....? If so how much? I know its been asked a million times but its nice to be able to have my own thread where I ca ask questions about a response if I dont understand it.
On the sae topic, whats the easiest andmost efficient way? Do I need to brace each frame section so it wont become 'Un-Square" ? If I section the crossmember will it make more or less problems? Mainly worried about clearance? Advantages to the z and sectioning VS just zing? |
THE TOY STORE
Re: Some "Z-ing" Questions unique to my application?
i did just the Z. was pretty easy just measure alot so you can keep everything square and level and i welded some rods across the frame on the top and bottom of the frame in front and behind the section i planed to cut. and yea you will need to raise the tranny tunnel also. i raised mine 3in just so i know it would work.
Oh ok....One of my biggest questions is where exactly did you slice the frame? Do you have pictures of that area and possibly of your trans tunnel befrore and after modification?
Thanks, James |
#4 | |
3DrDwn--the 'burb not the band
From one of my other posts on the topic
hope this helps liljim, and I'm pretty sure it's 2.5" min to set the main rails flat Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
Hey thanks for the tips. Where on the frame rails do I make the cut though?
There is no "one answer fits all" that's correct. The cut will be after the firewall of the cab but before the front suspension..... cut where it works best for you w/o interfering w/the cab. If you're not sure where that is, you're not ready to do a frame 'Z'.
THE TOY STORE
i used a strait edge and cut exactly were my firewall was. but like said theres no (one) spot. just somewere befor and after the crossmember. typicly the area were the frame starts to arc down towards the ground after the shock mount
100% gearhead
2-1/4 inches will bring the A-arms above the bottom of the frame rails. However, 2-3/4 to three inches is a good amount of Z. Keeps the lower A-arms from hitting the ground at full dump. As for tha spindles, arms and crossmember, this is the way I do it. There are many more ways, this is just my method. I cut away up to 2-1/2 inches (vertical) from the outside of the crossmember where the spring pocket is and use 3/16" plate to build an upper 'bag mount and use a plate for the lower A-arm. Add 2" drop spindles and the frame sets nicely (and hard!) on the floor. These measurements are for a front end using 27" or taller tires, so adjust the outer crosmember sectioning accordingly for the tire you plan on running.
#10 | |
and a few others
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Double 6's
OK, so I know mine is a different frame, (82) but we did a 3" Z. The cut was made where the frame starts to turn down to go under the firewall,(like someone said earlier) and figure out if you are going to BD the truck or not before you tunnel...just my $.02
oh, and my buddy that did the Z has a sheet of fairly thick steel on the shop floor to weld all of his body mount posts( to keep them in the correct places) mostly for building back-halfs and 3/4 frames, but he said it helped a bunch Z-ing mine! Dad always said "measure twice, cut once" GOOD LUCK and be patient! Last edited by badblu97; 12-11-2008 at 05:38 PM. |
#12 | |
There are guys out there that ask similar questions that are not ready but don't realize the fact. Then.... they start cutting up their truck only to have a big mess instead of a cool (& safe) ride.
