Old 02-08-2009, 07:59 PM   #176
krue
Designated A-hole!
krue's Avatar
Re: "Will it Ever Get Done?"
You're trying to make me look bad ain't ya? One of these days I have to get back to work on my truck.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-08-2009, 08:28 PM   #177
70LonghornCST
Moderator
70LonghornCST's Avatar
I wish I had half of your motivation.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 03-08-2009, 06:02 PM   #178
Well yard is all caught up, eye is mostly healed, no soccer today, so it is TRUCK TIME baby!!!
Before I had acquired some slivers in my eye, I had finished welding the piece for my fuel filler cover and I had also patched the passenger inner fender. Maybe I'll replace it some day, but the funds need to be used for something else. I finished stripping the inner fender, then sealed the underside with spray in bed liner. I also painted the engine side of it gloss black Rustolium. It'll match the driver's side now (minus the 4 years of dust).
Palf70Step is online now   Reply With Quote
Old 03-08-2009, 06:06 PM   #179
I sealed the fuel filler with some rust converter. I then cleaned it up on the underside and sealed it with spray in bed liner. I still have to do some filler work on the viewable side, but I'll wait till I have it tacked/bolted into place so it won't warp the filler.
Old 03-08-2009, 06:10 PM   #180
Between drying of pieces, I worked on my drivers front fender. I can't remember when I put this coat of filler on it, but it's been 6-8 months I think. I got it pretty close, but I think I'll need another skimming before I am ready to prime and block the whole truck.
Oh the last thing before cleanup, was to mount the grill from my 69 parts truck on the wall. A little to banged up for yuse, but a great wall hanging, like the 69's original tailgate.
Old 03-08-2009, 06:48 PM   #181
krue
Designated A-hole!
krue's Avatar
Looking good Bill!
www.daveramsey.com
Old 03-09-2009, 07:30 PM   #182
67ChevyRedneck
67ChevyRedneck's Avatar
Wohoo! Updates!
So is it going to make the meet?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-09-2009, 10:57 PM   #183
Originally Posted by 67ChevyRedneck View Post
Wohoo! Updates!
Only if someone places Their hand on it and performs a miracle.
Old 03-11-2009, 07:45 PM   #184
saintsfan
I am new here and was going through your build, then i realized that you are from Gulfport. i am also
saintsfan is offline   Reply With Quote
Old 03-11-2009, 07:51 PM   #185
Welcome to the board. Where you at in our fair city?
Old 03-11-2009, 10:45 PM   #186
saintsfan
i live in orange grove, off of dedeaux rd
Old 03-15-2009, 07:17 PM   #187
Little more got done today. I had filled the ridges of the bed floor with 3M seam sealer to level things out where the fuel tub will mount. This should allow for a decent seal between the bed floor and the tub.
I drilled mounting holes, then got it snugged into place. I then tack welded the tub to the bed side and wheel tub in a few places.
Once the welding cooled off, I tightened down all the bolts cleaned up the welds and seam area. I then applied some seam sealer around the edges of the fuel tub. I figured this would be a better way than welding it solid to the bedside and wheel tub. This way if I ever have to remove it (Lord, I hope not) I just unbolt, split a couple welds and off she comes.
That is about all for today. Once the seam sealer dries, I'll sand it smooth, then do a little filler work on the tub.
Old 03-21-2009, 05:16 PM   #188
You ever have one of those days? I was happy to get on the ole girl this morning. As I was starting I remembered as I looked at here I forgot to apply the seam sealer a little thinned down so it would smooth out nicer. Oh well, the old fashion sanding way to smooth it out first.
Sanded things down and applied some glass-hair filler to so I could smooth out the tub cut and welding seams a bit. More sanding, a little filler, more sanding. I decided to see how she looks with some primer.
I am pretty happy. I need to do a second seam sealer run (thinned out) and smooth out the seams. Other than that, I like the way it came out.
Old 03-21-2009, 05:28 PM   #189
Between sandings on the top half of the filler tub, I also worked on cleaning up and sealing the under/inside area of the tub.
I had coated it in spray on bed liner, but I knew it would burn off some where I tacked it on. So I got inside and cleaner around the weld marks, then rust coated the areas and added more spray on bed liner.
Onec everthing is finalized/assembled, I am going to seal the hole where the filler tube drops down with a heavy rubber mat. I think it should keep the majority of any road slime the tires through up out of that pocket.
Old 03-21-2009, 05:31 PM   #190
Went ahead and cleaned up the fuel door. Painted the inside with the color, but leaving the outside just primer until I paint everything. The door should sit a little more flush once I have the rubber bumper stops in place.
Old 03-21-2009, 05:37 PM   #191
As I mentioned earlier. it was one of those days. I was doing some sanding/blocking on some other areas to smooth things out on the front fenders and instead of making it better, I messed it up some (no pictures...I don't wanna be held accountable ). On well, I still got a bunch more sanding/blocking to do, but the ole girl is starting to look like a truck.
Old 03-21-2009, 07:03 PM   #192
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Awesome Bill..........Now get back out there and get to work.......
bad6772 is offline   Reply With Quote
Old 03-21-2009, 07:05 PM   #193
Nope! It's time to enlarge the belly!!
Old 04-05-2009, 08:45 PM   #194
Dasani
Dasani's Avatar
I like it; my next project, after my daughter’s truck comes home, is going to be a ’67 to ‘72 short-fleet. We went to see a guy yesterday who has several in different states of disrepair. We have to decide how much work we want to do. I’ll continue to follow your project.
Dasani
Dasani is offline   Reply With Quote
Old 05-16-2009, 08:58 PM   #195
Not a whole lot of photo graphical progress. Just lots of sanding.
I did acquire a few new items for the girl. I was up visiting GMan69 yesterday, and through a friend got the seat I have been wanting for a long time for here. really great shape too. It came of of a 92. I also picked up some gray visors out of a 92 Exploder today to replace the tan ones when I was going to use bucket seats. They should clean up pretty nice
Now the wife and son will be able to cruise together with dad.
Now I gotta get my butt in gear and
sand, sand, sand, sand....well you get the idea.
Hoping for some paint soon.
Old 05-17-2009, 12:25 AM   #196
67ChevyRedneck
Nice lookin' seat you got there!
About those stupid rubber thingys for the fuel filler door, put a dab of glue on them before you install them, I've already lost a couple of the stupid things. I've somehow popped them off while washing the truck, on both the 67 and my Z71. You have to pull hard on them to get them to install, so I never imagined they'd just fall off by hitting them with a sponge
Jesse James
Project "On a Dime"
Old 05-17-2009, 12:32 AM   #197
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Bill, it's coming along great. Keep up the great work. Your wheel tub mod has givin me another idea on where to put mine. Thanks
Alan's Classic is offline   Reply With Quote
Old 06-30-2009, 12:37 PM   #198
Man, sometimes I really hate body work. All I have been doing is sanding and resanding. Then I look at the thing and it seems like I haven't done anything. Eveyrthing still looks like a splotchy old truck. I think I am getting closer to where I can shooting the primer and color on the interrior.
Oh well, back to the grindstone, well sanding block.
Old 06-30-2009, 04:02 PM   #199
my67chevytruck
Under Construction
my67chevytruck's Avatar
progress.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-06-2009, 02:16 PM   #200
Still sanding. I did push the truck around in the shop. I need to get the thing so it can move on it's own.
Like I said earlier, just seems like splotchy ole truck. not too much progress or at least the look of progress.
Soon as the weather settles a hair, I'll be shooting the whole thing in epoxy primer and hopefully some color on the interior.
I did set up the struts I'll be using instead of hood springs.. Now all that should be left on them is to finish cleaning and painting the hinges.
