04-05-2009, 08:08 PM | #1 |
tubular motor mounts
I have these tubular motor mounts mounted before with some of the polyurathane mounts. The problem that i had before was my headers hit my lower a frame on the driverside. Plus my urathane mounts broke. So i went ahead and bought a set of solid mounts that are about 1/2 taller. Everything seams like they will work, but wondering if it will efect my drivetrain from lining up right. My engine seams to slant a little bit more to the rear. Any advise will be apreciated. here's a few pictures of what i have.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
04-05-2009, 08:11 PM | #2 |
Re: tubular motor mounts
Here's a couple more
04-05-2009, 10:12 PM | #3 |
looks good , vince
04-05-2009, 10:50 PM | #4 |
Dr. Frankenstein
is the trans,driveline, ect hooked up? they shouldnt have let it move but if all that isnt it could have....try to see if everything bolts up fine
I Wanna Go Fast!! |
04-06-2009, 06:06 AM | #5 |
everything bolted up fine, i don't have anything tight yet, because im waiting to get some new headers, and i may need to lift engine to slide them in.
04-06-2009, 10:01 AM | #6 |
Ready to go fast!!
what kind of compression do you got? you sprayin at all to get that 11.37?
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
04-06-2009, 10:01 AM | #7 |
Ready to go fast!!
i guess the nitrous question was stupid lol i dont see a plate shot or fogger system lol my bad
04-06-2009, 09:08 PM | #8 |
11/1 comp. plan on running a 125 shot mabey this year.
04-06-2009, 09:12 PM | #9 |
Dr. Frankenstein
should be fine then....so im guessing the 431" is whats left of a 427? nice truck by the way!!!
I Wanna Go Fast!! |
04-06-2009, 09:17 PM | #10 |
thanks joey, yea it's a .030 over 427
04-09-2009, 10:13 PM | #11 |
04-09-2009, 10:42 PM | #12 |
I run a mix 92 and 110. I have ran straight 92, but i don't get on it, just incase.
04-09-2009, 11:21 PM | #13 |
Looks good, but isn't a .030 over 427 a 433?
04-10-2009, 03:10 AM | #14 |
Dr. Frankenstein
im not sure if .030 over always amounts to the cubes added for each engine....depends i guess on the EXACT bore sizing down to super tiny i cant even spell numbers
I Wanna Go Fast!! Last edited by joeys66pickup; 04-10-2009 at 03:14 AM. |
04-10-2009, 09:08 AM | #15 |
Damn 11.3 for all motor is fast i was hoping to run this fast with nitrous when i'm done with my 427. Wat size stall are you running?
04-10-2009, 05:02 PM | #16 |
3800 stall
04-15-2009, 12:32 PM | #17 |
When I changed over to my brodix 10.600 deck block I had to lower my motor in the frame half an inch . So I just lowered the tranny mount half an inch to keep it at the same angle . Since you cant adjust your pinion angle on a trailing arm you might check the angle with the tranny in both positions and see which one best suits you .
NHRA Super Street 469C It only runs 10.90 at 156 mph |
04-15-2009, 02:16 PM | #18 |
You may have to adjust the exhaust to meet up to the headers flange properly. When installing the motor plate in my truck I went up with it as much as possible with a slight slant to the rear and I need to cut the collector off the exhaust and reweld it since the angle changed slightly.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 04-15-2009 at 02:17 PM. |
04-15-2009, 03:58 PM | #19 |
Dr. Frankenstein
thats weird, i noticed you didnt have to put washers under your mounts....I Did though? i have a set under the actual mount and under the bolt head like you huh.
I Wanna Go Fast!! |
04-15-2009, 05:03 PM | #20 |
I had a friend come over and look at it and he said the same thing about my engine leans back to much. So what i did was ordered new poly mounts from energy suspension which they said will not break!!!!! I also plan running a strap just incase. Plus a solid mount looks like it could eventually break the welds on my tubular mounts. I guess that if my new headers hit my lower a-frame again, i'll have to put some spacers underneath the tubular mounts. To bad they don't make a mount that's inbetween the 2 sizes that they have. I have also figured out that just a few washers can make a big difference!!!!
04-27-2009, 02:44 PM | #21 |
Sunburst C10!!!
how much do you want for the solid ones
and where did you get the lower mounts
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 04-27-2009 at 02:45 PM. |
05-06-2009, 12:26 AM | #22 |
where did you get those mounts?
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
05-06-2009, 02:02 AM | #23 |
Run it and see. You will know if somthing is off. I think this is the only way to be sure. You don't want to get too crazy though. Let us know.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!! 70 Chevy C-10, 355, th400, 3.73's 2/4 drop |
05-06-2009, 05:57 AM | #24 |
the tubular mounts came from performance online. The solid mounts came from moroso. I can't sell the solid mounts, they belong to a friend. He let me try them to see if they would work.
05-06-2009, 08:50 PM | #25 |
Sunburst C10!!!
thanks
do you have a website for both mounts
Gage 1967 C10 Shortbed Stepside |
