Old 04-24-2009, 06:52 PM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
Truck won't idle! help!
My truck started idling like pooh yesterday, the brake booster is messed up (have one on order) and I can hear it sucking air inside the cab. The booster has been acting up since monday, but the truck really started running crappy yesterday. Is the booster not letting the motor idle correctly, or am I off base here? I recently put a cap and rotor in the distributor and everything has been fine. Thanks in advance for any help.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 04-24-2009, 08:07 PM   #2
Boog
laying low
Boog's Avatar
Re: Truck won't idle! help!
Yessir. When the booster diaphram goes bad it allows the engine to loose vacumn and run rough. You will hear it sucking down by the brake pedal.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-24-2009, 08:10 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Thanks Boog, you're just right up the rode from me!
Adam
Old 04-24-2009, 09:16 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Don't run it much with the massive vacuum leak.It will cause a lean condition and may break your engine and bank,in that order.I think LHM has had this problem before.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-24-2009, 11:33 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
Well, i plugged off the vaccuum line to the brake booster and guess what... She still wouldn't idle. So, i took off the air cleaner, put my hand over the choke horn and she idled up, nice and smooth, which means, I still had a vaccuum leak somewhere. Turns out, the vaccuum line from the intake going to what used to be the modulator valve on the TH400 wasn't removed and plugged off when the Tremec 5 speed was swapped in. Duh....
Adam
Old 04-25-2009, 06:31 PM   #6
Boog
laying low
Boog's Avatar
Well that'll sure do it. Glad you found it.
Boog
primer is finer
