So Many Ideas, So Little Money
700R4 guys, clearances? how tight?
how tight does it fit in a low hump cab? anyone have one in withte motor inthe I-6 location? just curious how tence it will be in there
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
I don't have one in a low-hump, but it's not really bigger than a T-350. It's longer, but not really bigger. I'd bet it would fit fine. Especially if you move your engine forward to avoid cutting the driveshaft...
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
14.1 @ 96MPH
I have one in a low-hump, but the V8 is in the original V8 position...it worked great for me, I don't recall having to clearance anything...
Project1970 - LS1 Swap Complete! ![]() |
There is no problem putting a 700r4 in a low hump cab.
If this picture attachment works, you can see that it is not any bigger than a 350 or 400 tranny.
"Negative people always seem to have a problem for every solution" |
no one knows if its in the I-6 location thought? front to back in the hump area no problems at all?
ttt
mine's in the 6 location. there's a lip under there that i hadta bend a little bit cuz it was gonna hit (low hump cab)
68 short step, 406/700r4, 9" w/discs. |
just one lip? clear take it out or just trim it some? pics would be helpful thanks nate
L.E.D. Freak
You will have no problem installing a 700R4 The case of the 700R4 is the same size as a 350T You may have to relocate your tranny crossmember
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
Progress = 0%
You'll have clearance issues mounting it in the I-6 location. The pic below shows where it'll hit the hump. I fixed this problem by shortening my motor mount stands. That solved the problem, plus pulled the distributor away from the firewall slightly so there is no HEI-to-firewall interference
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
ok Jason, tell me how ou shortend your motor mounts and I'll think about giving you some credit, like, say ur not 100% stupid
ttt
TOTY 2006
![]() Join Date: Dec 1999
I glad you started this thread. I thought I had mine engine (350) in the V8 postition, and I have not yet tighted my cab mounts, and my cab is touching the 700r4 tranny. Is it possible that the rear tranny mount is taller then what is used for the 350turbo???
TTT Jason, where are you?
John- where is yours hitting?
