Old 06-09-2009, 11:58 AM   #1
Turbo85GMC
Turbo85GMC's Avatar
Stupid Bed Bolts
I'm trying to take my bed off for a c-notch install, and out of the 8 bed bolts, 4 of them spun. I was able to get 2 of the spinning ones with vice grips on the heads up top. Now I'm stuck with the last 2 up near the cab on the driver's side. I cut slots in the heads to hold them with a big screw driver from the top, but the screw driver wouldn't hold. I don't have a welder or I'd just weld a big nut on the top and use a breaker bar.
Unless anyone has any bright ideas, I think I'm down to just drilling out the head and punching them down. That should at least let me get the bed off in one piece.
When I go to put the bed back on, does anyone have suggestions on how to repair the "rounded" holes in the bed floor? Do I need to have some washers with square holes welded to the bed floor? Or do they make bed bolts with like an allen hole in the top?
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 06-09-2009, 12:04 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Stupid Bed Bolts
drilling out the heads and welding the bolts to the bed floor is what I would do
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-09-2009, 12:31 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
I think I have used a 3 inch angle grinder on them. You can pick those up cheap at Harbor Frieght if you need it quickly.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-09-2009, 02:01 PM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
If you are able use a sawzall or cutoff tool and cut the bed bolts from the underside. That will save the bed floor from getting messed up.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 06-09-2009, 02:07 PM   #5
babyJay
babyJay's Avatar
I agree, because if you use the grinder you will likely slip a little and get into the bed.
Jason
89 R3500 CC SRW
Old 06-09-2009, 03:12 PM   #6
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Take your vice grips and hold the the bolt shank near the end of the bolt (opposite of the head of the bolt) from underneath the truck. Then, you should be able to loosen the nut (without the head stripping).
Depending upon the type of finish you're after, I'd probably partially fill the rounded holes with weld, smooth them and then file them square.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 06-09-2009, 09:27 PM   #7
78 Chevyrado
I just tacked mine bolt heads to the floor and unscrewed them. It wasn't a problem so we just left them tacked in place and did all the body work and bedliner and then set the bed back on there without ever removing the bolts from the bed floor. some of them are still welded in there now.
78 Chevyrado is offline   Reply With Quote
Old 06-09-2009, 09:50 PM   #8
80chevyshortbox
80chevyshortbox's Avatar
when we took my box off i think we just grinded them to. but i dont rember.
80chevyshortbox is offline   Reply With Quote
Old 06-09-2009, 09:51 PM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i used a dremel with the cutoff wheels on the nuts and a hammer and chisel to knock off the nuts and thats how i got the bed off the 76
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-09-2009, 10:33 PM   #10
72lb4x4
You might try tightening them until they shear off...
72lb4x4 is offline   Reply With Quote
Old 06-10-2009, 09:05 AM   #11
tgh117
Crazy
tgh117's Avatar
You could also weld nuts to the top of the bed bolt, then you have something to hold on to.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 06-10-2009, 11:23 AM   #12
red caddy
The last time I fought the "bed bolt" battle, I just welded a piece of 1/4" X 1 " scrap flat bar (on edge) to the spinning bolts heads and spun the nuts off. The (useta be) square holes needed weld repair, but that's much easier with the bed off and standing on end... Paul.
red caddy is offline   Reply With Quote
Old 06-10-2009, 11:38 AM   #13
Turbo85GMC
Turbo85GMC's Avatar
Thanks for all the ideas. Sounds like however I get the bolts out I'll need to weld up the bed. I'm finding myself more and more frequently saying "I wish I had a welder to do xxxxx." Maybe it's time to spring for one.
'85 GMC 1500
Old 06-10-2009, 11:43 AM   #14
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Some of the weld this or that ideas are great, but he doesn't have a welder.
Getting the old ones off; if you can borrow a sawzall or a body saw, try to cut the bolt from the bottom side. Can you grab the bolt with vice grips from underneath, then try to get the nut off? Are you using an impact or an air ratchet or just hand tools? If you already made one slice in the head, make another slice 90 degrees across it. The head should pop off real easy then. Obvious and easy answer is a torch or plasma cutter if you know some one that has one.
New bolts; use smaller ID washer and hand file the hole square. Or you can buy long hex socket button head cap screws: and use a flat washer under them. Or if you don't care to be as close to correct as possible, just use regular hex head bolts.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-10-2009, 07:31 PM   #15
bumslie75
bumslie75's Avatar
i tacked them to the bed then just took the nut off
bumslie75 is offline   Reply With Quote
