06-04-2009, 12:21 AM | #1 |
Keepin it old school
Water coming out of my rearend..
No not THAT rearend..
The shop was cutting the stock brackets off my rearend in my 63 chevy pickup with a torch. The yoke was pointing down at the ground. Water began to leak out of the yoke and it was a pretty good sized puddle... He didnt crack open the rearend to look inside. We were wondering what this could be and if any of you have experienced this before? We were thinking maybe water over the years got inside the rearend or something.. I just thought Id ask if this means I get to buy a new rearend or what.. Thanks guys P.S. I live in a apartment so I cant do my own work. Just letting you know before you give me a hard time |
06-04-2009, 12:27 AM | #2 |
Happy to be here
Re: Water comming out of my rearend..
I think you need to pull the cover and see what it looks like. There is no "good" reason why water is in there.
06-04-2009, 12:34 AM | #3 |
06-04-2009, 01:26 AM | #4 |
06-04-2009, 11:17 AM | #5 |
Resistance is Futile
What about condensation from heating with the torch? A definite possibility in my thinking anyway......I would do a service on that rear end as soon as possible.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
06-04-2009, 12:22 PM | #6 |
Gearhead
Maybe the vent tube isnt properly "vented" with a check valve and the rear was allowed to fill with rain and various other sources of moisture??
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
06-04-2009, 12:53 PM | #7 |
That was my first thought
Joe |
06-04-2009, 03:19 PM | #8 |
Seņor Member
Not sure how it got in there. Several have made some logical suggestions. In any case, I think it's a very bad sign that warrants popping it open for sure, and possibly tearing down for at least new seals. If you find rust, you may be in for more work.
06-04-2009, 06:15 PM | #9 |
I have car A.D.D.
My question...not to sound like a 'donkey'. Are you absolutely sure it is water? Could it be diff fluid that boiled under the hot temps of cutting and welding, etc? Just a thought I had.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
06-05-2009, 08:37 PM | #10 |
Gearhead
Re: Water coming out of my rearend..
Yea I didnt even think of that, could be....
06-06-2009, 08:11 AM | #11 | ||
The vent and condensation issues are the most likely, but submersion is not out of the question either.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
06-12-2009, 06:49 PM | #12 |
Update on the situation - The guy doing the work pulled off the cover it was nasty inside real rusty and the gear oil looked like mud. The ring and pinion had grooves wore into them. The guy doing the work said he has never seen one that looked that bad. After looking it over he found that the stock vent setup had been removed at somepoint so there was just a open hole. Thats how the water got in..
Sooooo I had to spend another $300 bucks at summit on a new Richmond 3:73 gear set and mega install kit.. Last edited by Bazooka; 06-12-2009 at 06:51 PM. |
06-13-2009, 10:32 AM | #13 |
Happy to be here
Yes that sux, but at least you have no more water oozing out of your rear end....and that's a good thing.
