Old 06-16-2009, 11:01 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
hmmmm bad or not?
ok so i took the after market breather off my valve cover cuz it wasn't working any more...so i put the stock one back on and then cut the after market one open and i noticed that the foam inside of it was completely full of oil....is that a bad thing and if the after market one is full of oil dose that mean that the stock one is just gunna suck up oil into the intake cuz it doesn't have any foam to stop it
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 06-16-2009, 11:37 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: hmmmm bad or not?
Are they the stock valve covers? Stock ones should have a baffle around the opening on the inside to prevent oil from escaping there.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-16-2009, 11:41 PM   #3
pokethesmot
there not stock but they do have baffles
Old 06-17-2009, 07:04 AM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
In my years of working in the quick lube industry I saw many breather elements saturated with oil. It usually is attributed to worn piston rings causing "blow-by". I wouldn't be too concerned about until it pukes enough to re-enter the carb, or ejects the dipstick out of the tube.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-17-2009, 08:22 AM   #5
85sqbdy
85sqbdy's Avatar
It sounds like your building crankcase pressure and it has nowhere to go. Check your pcv valve. My 85 BBC did the same thing because i was not running a pcv system. It would puke oil out the breathers. I installed taller valve covers and a pcv system and the problem solved. No more messy valve covers. It had no blow-by, just too much crankcase pressure. I went with the taller v/covers because i had them, and plus , they just look better.
.before
.after
if it ain't broke, fix it until it is.
85sqbdy is offline   Reply With Quote
