WTB - rag joint for 1972 Blazer
I just need the end that goes into the steering gear box.
The whole end...not just the rag joint but that plus the metal piece that is connected to the gear box. Need it in decent shape with splines intact and not hammered off ;-)
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. Last edited by scoyote; 06-17-2009 at 02:39 PM. |
![]() Join Date: Apr 2005
Re: WTB - rag joint for 1972 Blazer
Powersteering or non?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Resident Curmudgeon
![]() Join Date: Dec 1999
I just bought this one, it's a direct replacement for our power steering gearboxes
http://www.1aauto.com/1A/ChassisSusp...C00031/1161262
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Power steering
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
I checked out that link but couldn't find a 1972 listing.
Did you use that on a 1972?
Resident Curmudgeon
yes,direct fit
Try Tedroe Auto Salvage in Tedroe, Ohio. They have new ones for both manual and power steering. Yeah, if ya got power steering, you want the gigger of the two. Most parts places simply sell the rag joint, not the splined ends. I just converted my 67 from manual to power steering and they were a big help. Got the pump and bracket off a 72 Impala with a 250 six like mine. The gear box came off a 75 C10. Napa supplied a new pressure line and hose for the return line, not to mention new belts. Sure is great not to have to DRAG the old grey mare around corners any more.
What's the diff between the power steering and non-power steering ones? I recently did a rag joint swap on my power steering one from parts in the shed, and now I wonder after reading this ....
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
Here...there are several to choose from...so make sure you order the correct one...Real nice quality...I just got mine installed on my new quick ratio set up!
http://www.americanclassic.com/asp/d...ype=to&exyear=
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 08-23-2009 at 01:28 AM. |
