Old 07-11-2009, 11:15 AM   #1
fdbdw
fdbdw's Avatar
white smoke
Getting white smoke out the tail pipe, quite a bit on a cold start then real light while running. I know moisture can cause white smoke but was wondering about a lean mixture or timming, I have edel 1406 and due to living at 6000' Ive put in leaner rods and jets also been playing with the timming. So I was wondering if I went to lean or somthing besides moisture can cause it
fdbdw is offline   Reply With Quote
Old 07-11-2009, 11:44 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: white smoke
It's possible to just have condensation in the mornings when you first start it and then a slighly rich mixture may produce a light gray smoke. Sometimes it's hard to distinguish.
Also, if you are in a cooler climate it's possible the exhaust is condensing. Sort of like a high flying jet. Auto emissions does creat moisture.
But, after saying all that, I'd check for bubbles in the radiator when you first start it or have someone leak test it. You my have just a slight head gasket leak.
68gmsee is offline   Reply With Quote
Old 07-11-2009, 07:07 PM   #3
hugger6933
Re: white smoke
check the vaccum modulator on the transmission. It is possoible if the diaphram to rupture or leak and trans fluid could be sucked into the motor. It is kinda unusual to have that on start up. Jim
hugger6933 is offline   Reply With Quote
